Radius arm bushings
Old Apr 26, 2006 | 08:48 PM
67f100's Avatar
67f100
Radius arm bushings
Any trick to getting new bushings (the outside one) on? I am trying to flatten out the arm by jacking up the suspension but there is no room at the top for the bushing to go in and the inside bushing is all the way in, any suggestions?
Old Apr 30, 2006 | 06:05 AM
lee armistead's Avatar
lee armistead
first, make sure that you have the correct bushings. It would appear the the radius arm is not protruding through the bracket far enough. As a last resort try using a come-along to seat the arm through the bracket. Also, I've seen the new bushings are larger in dia. and the heads of the bracket bolts prevent full seating. Lee
Old Apr 30, 2006 | 06:08 AM
lee armistead
One other thing. I've also had this problem when trying to put the nut on with the large washer. I put the nut on, tighten against the bushing itself and pull the arm into the bracket just enough to get the washer space, then remove the nut and install the washer and nut together. Lee
Old Apr 30, 2006 | 10:00 AM
Torque1st's Avatar
Torque1st
Posting Legend
A come-along and a prybar will align them.
289 sprint
1966 - 1977 Early Broncos
Apr 9, 2015 08:45 PM
shadetreemobile
Aerostar
Oct 4, 2011 09:23 PM
89BroncoResto
1978 - 1996 Big Bronco
Oct 31, 2003 10:48 PM
fatdaddy
Jun 29, 2002 08:14 PM
