Door Hinge Trouble.
Old Apr 26, 2014 | 10:37 PM
Zeat's Avatar
Zeat
Door Hinge Trouble.
Received my new bushings and pins from bronco graveyard today. While taking the top hinge off the cab on the pass side, the threaded steel plate that the hinge bolts to fell down out of site. Was planning on blasting the hinges in the cabinet until this happened. Any suggestions would be very welcomed.
Old Apr 27, 2014 | 01:00 AM
co425's Avatar
co425
That plate is captured. Sounds like the tabs that hold it in place may have rusted out. You will have to cut into the cab to get to it unfortunately.
Old Apr 27, 2014 | 01:30 PM
bucks77ford's Avatar
bucks77ford
Not how far it can fall..never seen it happen before, but you could try to use a long flexible magnet tool to retrieve it and them if you can get it, screw a bolt in place so it doesn't fall again and then may have to tack weld it in place to get the hinge back on.
Old Apr 27, 2014 | 07:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The plates were only furnished with the front body (A) pillar (02500 R/S shown in pic).
If the plate could be welded back on, how then could the hinge be adjusted?
Old Apr 27, 2014 | 07:15 PM
bucks77ford
If he could retrieve it and tack weld just to get the hinge back on, then break the tack weld for adjustment. Just a thought.
Old Apr 27, 2014 | 09:20 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That part is meant to be (captured) attached anyway, with tabs ? or just weld the plate back on.
It the hinge that adjusts, not the backing plate. Sounds like a yes to cutting into the cab and getting it back in place and welding from the back side.
PITA, but doable.
keg99
May 15, 2016 08:31 PM
cruisetopdown
34
Feb 10, 2013 12:14 PM
twinzilla
Nov 7, 2012 12:57 AM
big red c222
Apr 19, 2009 08:24 PM
g84t8f1
Mar 31, 2008 07:39 PM
