Fuel Problem - HELP!!! :)
Old Apr 26, 2014 | 04:33 PM
glennemay's Avatar
glennemay
OK,
SO the other morning, my son tries to start the '79 F250. It turn and turns and turns. Hmmm.. Maybe out of fuel. add some from the can. Turns and turns and turns. Spray a little either.. *Cough*, *Spit*, *Whir*, stop..... Hmmm.. not much fuel in the in-line filter. Change filter. Nope.. Same.. OK.. Fuel pump must be bad. Change fuel pump.
Now, new pump, new filter, all nice and connected.. SAME DAMN THING!! no fuel coming up to the filter at all.
Running out of ideas. Any help is appreciated.
Thanks
G
Old Apr 26, 2014 | 04:42 PM
Falconman#3's Avatar
Falconman#3
Does the truck have a inline filter from the tank to the fuel pump?
Old Apr 26, 2014 | 04:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1AZ-9A011-A .. 3/8" ID Plastic Meshed Filter Screen / Available from Ford / Slides onto the end of the fuel tank senders pickup tube. Gets clogged up with rust and scale.
1971/79 all FoMoCo vehicles except 1971/77 F100/350's with in-cab fuel tank. Except 1971/77 Maverick/Comet & 1971/79 Pinto/Bobcat that use D1FZ-9A011-A 5/16" ID filter screen.
Old Apr 26, 2014 | 07:00 PM
glennemay's Avatar
glennemay
Yes. Actually, there are 2 of them. One in the fuel line, and one at the carburetor. We changed the large clear one in line, and checked the one at the carb. The fuel is not making it to the clear filter which is where we are getting stuck.
I even went as far as to hook a vacuum up to the fuel line and try to pull from the tank forward. Still nothing.
Old Apr 26, 2014 | 07:04 PM
glennemay's Avatar
glennemay
Bill, our next step is to drop the tank. However it is pouring outside and lying on the ground seems a little, well archaic in the rain. Yep. I'm old.
However my question to that is this. it is a plastic tank. We have been wanting to replace it because there is a pinhole someplace that we cannot find.
If anyone knows where I can get a replacement tank, that would be AWESOME I have found a couple, however everytime I call or try to order they are out of stock with no known replacement date.
Thanks
G
Old Apr 26, 2014 | 07:29 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here you go maybe this will help?
1973-79 Ford Pickup Truck Fuel Tank
MTS COMPANY, L.C. - Ford Pickup fuel tanks
http://www.fuelpumpwholesale.com/ite...32&mfr=SPECTRA PREMIUM IND., INC.&weight=13
1972-1979 Ford F Series Pickup Rubber Fuel Filler Neck Hose (FRONT TANK) | Filler Neck Supply Co.
O'Reilly's sells Spectra (Canadian made) brand metal ones for 100 ish?...FYI their sending units can come with the a 3/8 or 5/16 line port (3/8 is correct, I do believe).
http://www.oreillyauto.com/site/c/se...250&vi=1123300
Old Apr 27, 2014 | 07:37 AM
glennemay's Avatar
glennemay
List: Fuel Tank - 1979 Ford F-250 | O'Reilly Auto Parts
Thank you.
The problem I keep running into is that it is a 4x4 and it came stock with the plastic tank (From what I can tell) and none of these seem to be for that truck.
Does anyone know if the 2x4 will fit? I hate to order a tank in to find out that I am a moron.
Thanks
G
Old Apr 27, 2014 | 07:39 AM
glennemay's Avatar
glennemay
Originally Posted by glennemay
Thank you.
Thanks
G
I should have also mentioned that this is the front tank. The previous owner removed the rear tank and all of the supporting brackets. Have not gotten that far yet...
Old Apr 27, 2014 | 08:13 AM
77&79F250's Avatar
77&79F250
2wd side tank is metal, 4x4 is plastic yes. You can get a rear plastic (item 4250) to replace the standard metal on from the site below.
Item 4249 or 4249A is the plastic side tank. 4250 is the rear with EMS port.
PM sent.
Old Apr 27, 2014 | 08:23 AM
77&79F250's Avatar
77&79F250
More info for you, and thanks ND or mike o0o0o0.
78/79 duel fuel tanks frame switch-Duralast/Universal 3 port fuel selector valve used with SW48 toggle switch Part Number: FSV4
There are two differences between the tanks. Tanks with EEC have a hole in the top center of the tank. A rubber grommet and check valve are pressed into the hole. A line goes from the check valve along the inside of the passenger side frame rail to the engine compartment where it hooks up to a charcoal canister. Non-EEC tanks don't have this hole. The other difference is the nipple for the breather line that is located right next to the nipple for the filler hose is located 180 degrees opposite.
If you are going from an EEC tank to a non-EEC tank you must also change the fuel cap to a vented style. The EEC tanks are vented through the EEC system and use a sealed fuel cap. Non-EEC tanks vent through the fuel filler cap.
If you run a non-EEC tank and a sealed cap the minimum is you'll have fuel starvation problems, at worst a collapsed fuel tank.
Is your truck a longbed 4WD? Does it have evaporative emission system?
There are two possibilities with the plastic tank.
79 F150-350 regular cab, 133" WB 4WD, w/ evap. emissions system, 24.8 gallon mid-ship plastic tank
D7TZ-9002-C
Same w/o evaporative emissions system 26.3 gallon plastic tank
D7TZ-9002-D
Fuel sender
76-up F100-350 >s/n C00,000
Use with aft axle steel tank, includes gasket
D7TZ-9275-D
Bob Hoover Ford-Mercury, Vienna, IL has 1 (618) 658-9218
Brighton Ford, Brighton, MI has 1 (800) 336-3305
Beau Townsend Ford, Vandalia, OH has 1 (937) 898-5841
Own Ford, Jarratt, VA has 1 (434) 535-8515
Vintage Fords, Beaver Dam, WI has 116 (!) (877) 846-8243
Old Apr 27, 2014 | 02:57 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Well, the tank solenoid is behind the front tank mounted on a cross member. See if you are getting anything to either side of that, they do go bad. Does it still have the switch on the dash? If so what position is it in? Is the fuse going to the solenoid good? Is the solenoid plugged in? If you have no aspirations to re install the rear tank, maybe you should think about just bypassing the solenoid if you haven't already. Good luck.
Old May 13, 2014 | 10:56 PM
thatsrealnice's Avatar
thatsrealnice
I've been reading about fuel sending units and tanks, and from what I've gathered, the mid ship tank is plastic on 4 wheel drives. I have a 78 supercab f250 4x4 and both tanks are steel. Just wondering if someone had replaced the mid ship tank with a steel one at some point, or could someone specify from factory to have it steel instead of plastic? Anyone know?
Biohazard74
Jan 31, 2019 11:07 PM
Jaynes
15
Nov 12, 2017 06:08 AM
CarolinaRanger
Feb 12, 2015 03:15 AM
mrlinder151
Jul 22, 2012 10:06 AM
sh1520
Sep 27, 2007 09:44 AM
