1978 - 1996 Big Bronco
Ongoing starting trouble.
Old Apr 30, 2014 | 09:24 AM
Encho's Avatar
Encho
The Southernmost Mod
Another thing you might want to check is the coil and it's wiring. Dying coils sometimes do exactly what you're saying, does it run fine when you manage to start it or when it gets warm?. I suspect the battery cables are the cause, but you have to rule out any other causes. Touch the starter solenoid, is it getting too hot?.
Old Apr 30, 2014 | 03:50 PM
Quinnbristow's Avatar
Quinnbristow
I have a new solenoid in it. Even when the engine is at full temperature, the solenoid is cool.
When it does start, it runs beautifully. (As beautifully as 350,000 miles will allow)
One thing I have noticed is when I have the AC on, and I'm idling at a light or something, the AC clutch almost kills the engine when it engages. It actually has killed the engine once or twice. I just assumed the compressor was bad and dragging heavily.
Pardon my ignorance, but is the coil built into the distributor?
Old Apr 30, 2014 | 03:58 PM
Tedster9's Avatar
Tedster9
Bad AC clutch will do all that, and more?
Sent from my iPhone using IB AutoGroup
Old Apr 30, 2014 | 10:38 PM
Quinnbristow
Well, just replaced my cables. No avail. If anything, it's worse. With how hard it is to turn over the engine, maybe it's the battery? It is new-ish, from November 2012. I'll try returning it.
Old Apr 30, 2014 | 10:42 PM
andym's Avatar
andym
It's worse in what way?
Old Apr 30, 2014 | 11:27 PM
Quinnbristow
It's turning over even slower when it's colder. It may not start at all when I go out to it tonight.
timmygyu
Oct 29, 2012 06:06 PM
firemedic30016
Nov 21, 2004 01:23 PM
spixican07
Dec 1, 2002 03:08 PM
Bluef4x4
Jan 30, 2002 11:23 PM
