Aerostar Ford Aerostar
1996 EEC power relay and FP driver wire testing?
Old Apr 26, 2014 | 10:42 AM
fast68's Avatar
fast68
have a 1996 3.0L RWD that seems ot have no power to PCM or FP
engine light never comes on
and no power at inertia safety switch.
all fuseable links and fuses are good. yellow switched power source wires all hot with key in run position hood, at the PCM as well.
and the red full time hot wires are good everywhere too including at the PCM and injectors, etc.,
there are three identical black relays at the battery along with a white diode. apparently the diode is inline with the yellow swiched power source wire to the PCM and it is fine as well -being that i have power at the pcm via this wire- in the ign. switch run position.
none of the three relays under hood are keyed and they all have the exact same part number on them. the power relay seems to be functioning fine.
isnt there supposed to be SES or CEL light in dash with ignition switch in run and/or engine cranking position?
i put power to the FP power wire terminal at the FP relay socket plug and the FP operates very well.
the PCM wont send power to the FP relay to run the FP.
the PCM wont do anything at all that it needs to be and should be doing,
so the PCM must be fried?
right?
thanks much! for anything at all ?!
Old Apr 26, 2014 | 10:54 AM
KhanTyranitar's Avatar
KhanTyranitar
Those three identical relays, one is the fuel pump relay, one is the EEC relay, and one is the AC clutch relay. So you already found it. Replace the faulty relay and move on.
Js3
May 2, 2024 12:42 PM
elkkiller34
Jul 18, 2017 01:41 AM
Bronco POPO
Bronco II
Mar 4, 2011 12:44 PM
DROPDOUBT
1983 - 2012 Ranger & B-Series
Jan 21, 2008 09:11 AM
gaknut
Aug 13, 2004 05:16 PM
