About starters
Old Apr 24, 2014 | 04:42 PM
toby tough's Avatar
toby tough
About starters
So I got this nice starter from Ross awhile back. Thank you very much by the way. I put new brushes in it and basically gave it a tune up. I was looking at the drive end of the two and my old one has a different bendix on it. It has a thin spring that keeps the drive gear? pushed away from the starter somewhat. There is a collar of sorts that it rests in and I'm wondering if I should swap it to the newer starter. It will probably be OK, but I'm just curious.
Old Apr 24, 2014 | 05:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Can you put up a pic of the old Bendix?
Glad it is working out for you!
Old Apr 24, 2014 | 06:58 PM
toby tough's Avatar
toby tough
I took a pic of both of them for comparison. The one on the right is the springy one.
Old Apr 24, 2014 | 06:59 PM
toby tough's Avatar
toby tough
I guess it's the one on the bottom.
Old Apr 24, 2014 | 07:13 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
It's on the right on my screen.
Anyway, the one on the left (or the top) is like my starter in the 226.
Old Apr 24, 2014 | 07:47 PM
Wayne Waldrep's Avatar
Wayne Waldrep
When I got my truck I got an extra starter with it. I had exactly what you have....one of each type. At one time I thought I had starter drive problems and I put the other one in. Either one worked for me. One is sprung and the other works off the spinning action and uses the "threads".
Old Apr 24, 2014 | 07:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As long as they are the same distance when sitting there, from the back plate of the starter, and both have the same number of teeth, I don't think it matters. I believe there are threads hidden under the one on the right, too.
Old Apr 24, 2014 | 07:56 PM
toby tough's Avatar
toby tough
Thanks guys. I searched around a little bit and couldn't find a bendix that had the spring on it.I wonder if it was a car type starter or maybe one off a tractor or something like that. Dunno.Not real familiar with these old trucks yet so it's still a learning experience for me. If I could only find someone who would submit to the Vulcan mind meld......
Old Apr 24, 2014 | 08:06 PM
toby tough's Avatar
toby tough
Yeah, the one with the spring has the threads too. I'll have to check on the tooth count. When I pop this back in should the drive gear be towards the big spring?,and too the rear of the flywheel? Could take a little finagling to get it in there right I spose.
Old Apr 24, 2014 | 08:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, to the rear. You usually have to corkscrew them in there, and of course the bolts that hold it together can't be in, so... have fun!
WaveyDavey1980
Apr 18, 2019 09:31 PM
CaptainIPSC
Oct 28, 2012 08:52 AM
jhuffer
Aug 9, 2003 02:01 PM
Forticitius
Offroad & 4x4
May 3, 2003 09:53 PM
