E4OD issues
Old Apr 22, 2014 | 12:51 PM
Snipeston's Avatar
Snipeston
E4OD issues
I think my E4OD in my 95 f150 is slipping in 4th gear. Just started the last couple of days, the engine rpms stay steady but the speedometer bounces around 3 to 5 mph. Any thoughts? Thinking rebuild of the trans, but not kind of new to this area, my experience is im older Jeeps....
Old Apr 22, 2014 | 01:08 PM
wjb21ndtown's Avatar
wjb21ndtown
If it's not having trouble shifting gears, or skipping, it could be a torque converter issue.
Old Apr 22, 2014 | 01:28 PM
Snipeston's Avatar
Snipeston
Yeah its just the slipping in 4th gear between 55mph and 70 mph
Old Apr 22, 2014 | 01:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the RPMs are staying steady then the transmission is NOT slipping. You have a speedometer problem, not a transmission problem.
Old Apr 22, 2014 | 02:15 PM
Snipeston's Avatar
Snipeston
Well thats what i thought too based on my experience. I can feel the vehicle buck or kick (for lack of a better word) when the speedo is doing this. What else could be causing this? Thanks in advance for the help and ideas.
Old Apr 22, 2014 | 04:01 PM
Mark Kovalsky
It could be an engine miss. It could be electrical issues. Are there any codes stored in the computer?
Old Apr 22, 2014 | 04:12 PM
Snipeston's Avatar
Snipeston
No check engine lights, I dont have a reader for obd1 systems. Isnt there a way to retrieve codes without a scanner on obd1 engines?
Old Apr 22, 2014 | 05:32 PM
Mark Kovalsky
There is. It takes a sophisticated tool called a paper clip.
Bassjunkie87
Mar 2, 2015 10:33 AM
fordtruckboyf150
26
Mar 19, 2007 08:14 PM
LogicalRetard
Feb 12, 2006 07:42 PM
ford351c
May 30, 2003 03:47 PM
