Water pump replacement
Old Apr 21, 2014 | 08:08 PM
kla94's Avatar
kla94
Thought I would just start my own thread,instead of hijacking VaFordman26's. Here's what I got done this evening.
There's some scale build-up in my radiator,any suggestions on flushing it?
I'm also gonna put my thermostat that I've had laying around for two years in! It's a motocraft and I'm gonna check it before I install it. Gonna take my mechanical lift pump out and put the block-off plate on. And put my power steering line on that's been laying around. Just call me a procrastinator! Thanks goes out to akamacyver yet again for the wrench trick to getting the fan clutch off!
Old Apr 21, 2014 | 08:22 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
helpful info..............
CAUTION!!! "The Old casting requires the proper bolts in the upper mounting holes, or they will hit the IP gear."
Originally Posted by fonefiddy
All fan clutch nuts are LHT, the Serpentine belt/Fan Clutch is jsut as much a PITA as the V Belts. Your going to need a special wrench set to get the nut off.
FWIW, the Water Pump design was changed. In 88/89?? IF You get a new casting, the bolts are all the same. If You get an new casting, the upper bolt bosses are longer and You don't need to worry about the bolts hitting the IP gear. The Old casting requires the proper bolts in the upper mounting holes, or they will hit the IP gear. See Pic Link Below.
Old Apr 21, 2014 | 08:27 PM
kla94's Avatar
kla94
Thanks 250. I did remember reading this awhile back.
Old Apr 21, 2014 | 09:08 PM
d-day's Avatar
d-day
I used a super strong strength muratic ( I think that is how you spell it) acid , when my radiator was out. I think I use 3 gallons and let it sit, then I power back flush the radiator . I rinsed with clean water used baking soda to neutralize the acid mine was just as bad as yours or worse, but it came out super clean like it was brand new inside
Old Apr 22, 2014 | 08:11 PM
kla94's Avatar
kla94
I have some brick acid, which is muratic. Thought about that, but just wasn't sure what it would do to my radiator. Thanks.
Old Apr 22, 2014 | 08:33 PM
kla94's Avatar
kla94
I opened my NEW water pump from my local carquest and look...
gonna use it, but it was a little shock to me.
Old Apr 22, 2014 | 09:54 PM
Macrobb's Avatar
Macrobb
What, made in China?
You think anything *isn't*?
Old Apr 22, 2014 | 10:21 PM
Chevy_Eater's Avatar
Chevy_Eater
Stupidity is still Made In America. I see tons of it every day.
d-day's Avatar
d-day
As long as it is a copper brass radiator you will be fine, just make sure you neutralize the acid afterwards
Old Apr 23, 2014 | 07:40 PM
kla94's Avatar
kla94
Yes, I know. Shouldn't be a shock. What's the best way to get to the non-pressure line on the steering box. Thought that I would replace my leaky line, but I'm having trouble even with the radiator out. Which radiator should I use? Mine has a leak that has been there for a little while. I know that champions are not too reliable.
Old Apr 23, 2014 | 09:02 PM
Chevy_Eater
It'd be nice if a quality replacement was still available, but all I'm hearing are stories of crap, 2 core, plastic tanks, now the problems with Chumpions...
14-15 years ago I got a new one at a local radiator shop for the '84, looked like a direct replacement for the stock one. Buying it hurt though, $400. But if that's what it takes for a good one it was probably worth it.
Old Apr 23, 2014 | 09:08 PM
Chevy_Eater
Out of curiosity, (my '85's going to need one eventually), I checked RockAuto, they have all the typical low cost crap, but this one at the bottom sounds like a possible stock replacement:
<table class="parts"><tbody><tr><td class="left" style="padding:0px; margin:0px;"><table class="layout" style="padding:0px; margin:0px;"><tbody><tr><td class="partlayout">VISTA-PRO Part # 432194 {#1165, 9334} Ready-Rad; Mounting: Front Flange
COPPER / BRASS; W/AC; W/H.D. COOLING; W/MAX COOLING</td></tr></tbody></table></td><td class="right" style="height: 40px;">
</td></tr></tbody></table>$406.79
Looks like a grab your ankles if you want it, but throwing money away on a cheap o is a losing proposition.
Old Apr 23, 2014 | 09:10 PM
Macrobb's Avatar
Macrobb
Why not just fix it?
Find your leak, and see if you can't solder it closed. Being brass/copper, there should be no reason you can't solder it shut.
Also, depending on how 'stock' you want it, a jy unit might be a good value. If it's even close to the same size, it should work fine -- I'm now of the opinion that our radiators are fairly well oversized for the application(which is nice).
Old Apr 24, 2014 | 07:22 PM
kla94's Avatar
kla94
My dad's gonna take my radiator to a local machine shop tomorrow. They fix radiators and all kind of stuff. They think highly of their work, but it's done right. Figured this would be my best bet. Got my power steering line on and got my old pump off and cleaned the old gasket off. Got to get some bolts for my fuel pump block- off plate.
mozzles
40
Aug 29, 2014 10:53 PM
VaFordman26
30
May 4, 2014 11:34 AM
KrautBurner
15
Mar 21, 2012 11:34 AM
Galendor
Jul 16, 2011 04:42 PM
tangofox71
Apr 26, 2010 02:20 AM
