01 7.3 going into a 96 f250
What i was saying was that the pins I named off I said were unused on my schematics and its wierd that the ones you had named off are all used on my schematics. With that im not sure which is correct, yours or mine. Eh, another standstill in my project! D:
I took the Ford wiring diagrams and dropped the pinouts into a spreadsheet. The OBS engine wiring harness would be plug and play with the 2002 chassis side of the wiring harness. The 2002 and 2001 should be identical. Myself, I'd splice the SD valve cover connectors into the OBS harness and use the SD valve cover gaskets. They have less tendency to over heat at the glow plug pins. Here's the comparison:
dcelrod
05-09-2016 09:36 PM
