Need engine harness
Old Feb 11, 2015 | 03:56 PM
kbarbee95's Avatar
kbarbee95
Need engine harness
I need a engine harness that work connects to a 97 motor but plugs into a '00 f250. Can I just use a regular '00 engine harness? Or do I have to splice them together? The harness thats on there is connected with a bunch of butt connectors they got all twisted up and just look nasty.
Old Feb 11, 2015 | 06:25 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
The 2000 harness is what you want I think. I don't know if the pin layouts would be the same on the 42 pin connector from the 97 to 00. Some of the sensors are different though
Old Feb 11, 2015 | 09:48 PM
fordpride's Avatar
fordpride
It doesn't exist. You have to splice it or change the harness and re pin the pcm connection
Old Feb 11, 2015 | 09:53 PM
fordpride's Avatar
fordpride
And if the engine isn't a Cali engine then it isn't going to run correctly. Cali engines have split shot injectors like the SD do. States truck have single shots.
Old Feb 11, 2015 | 09:54 PM
madpogue's Avatar
madpogue
Wouldn't it be best to put all the original '00 sensors, senders, controls, etc. on the '97 engine, and keep all the original '00 wiring? IOW, just use the _mechanicals_ of the '97 engine?
Old Feb 11, 2015 | 09:58 PM
fordpride's Avatar
fordpride
That's what I'd do
Old Feb 11, 2015 | 11:10 PM
MOOSE_MACHINE
Same here.
CSANDERLIN
Mar 19, 2018 04:38 PM
fludoc
21
Feb 11, 2016 09:20 AM
lght1
13
Jan 15, 2013 03:58 PM
bigbrown1985
Sep 13, 2012 12:51 PM
