Brake Controller Mounting location??
Old Apr 19, 2014 | 10:20 AM
DmanNC's Avatar
DmanNC
I have an 06 expy, It doesn't look like I have a lot of options for mounting a brake controller , but any ideas would be great. I was thinking right above the gas pedal would be the only option.
Old Apr 19, 2014 | 11:03 AM
SilverSS's Avatar
SilverSS
I don't know exactly how the inside of the newer expy's are but i normally mount mine farther to the right of the gas pedal (some place it's not easily kicked) and high enough where it can still easily be reached in case you ever needed to manually hit the brakes in an emergency. Is there a pocket you could put it in? Do you plan on permanently mounting it or taking it out when not in use?
Old Apr 19, 2014 | 12:57 PM
DmanNC's Avatar
DmanNC
I have a center console and no pockets, but i think I can mount it high enough to keep from hitting it. I will leave it in the expy, but it comes with a clip that I can take it out easily.
Old Apr 20, 2014 | 08:38 AM
99expyTN's Avatar
99expyTN
Look at this thread. I posted pictures of my mounted brake controller. Of course, mine is a '99 so it may not even be applicable.
https://www.ford-trucks.com/forums/1...ontroller.html
Old Apr 20, 2014 | 05:30 PM
DmanNC's Avatar
DmanNC
Thanks for the reply, but mine has no pocket, so I put on the left side of the steering wheel, just above the brake and hood levers. I will post pics here shortly.
Old Apr 20, 2014 | 05:57 PM
DmanNC's Avatar
DmanNC
Old Apr 20, 2014 | 09:19 PM
alloro's Avatar
alloro
Careful that your leg doesn't keep banging it as you get in and out.
Old Apr 22, 2014 | 08:48 AM
DmanNC's Avatar
DmanNC
I was worried about that, but this was the only spot that I could see it easily. I did check for leg clearance and with the key in I do have to watch it. But with the key out the seat slides back and I have plenty of room. So I thought I would try it, so far so good. I did hit it once when I was hooking the camper up, but if becomes an issue I will move it to the other side.
Old Apr 23, 2014 | 05:02 AM
broncoholic's Avatar
broncoholic
In my 03 (basically same truck), mine is on the right side and a little more towards under the dash. My display is more towards the top of the unit so it's still easy to see with it under the dash.
Old Apr 29, 2014 | 09:36 AM
Mark T-TB's Avatar
Mark T-TB
I mounted it on the right side, up just a little higher toward the i.p.
Pele
May 1, 2018 03:33 PM
Nothing Special
May 8, 2017 09:26 PM
MikeMcCasland
Aug 9, 2009 08:09 AM
Dexsure
2004 - 2008 F150
May 28, 2006 09:10 PM
xc600
2004 - 2008 F150
Dec 7, 2005 09:21 AM
