Location for brake controller?
Old Nov 28, 2013 | 07:06 AM
ltng7679's Avatar
ltng7679
Any suggestions on where to mount the electric brake controller on a 2003 exp xlt? A picture might help
Thanks
Ed
Old Nov 28, 2013 | 11:55 AM
alloro's Avatar
alloro
If you have the factory tow package option, there is a plug for it up under the dash on the driver's side.
Old Nov 28, 2013 | 03:10 PM
r2millers's Avatar
r2millers
After plugging into the port that alloro is responding about, I attached the aftermarket controller to the removable fuse cover, just above the parking brake lever on the left side of the steering wheel.
That way it is easy to access the manual brake bias easily when adjusting brakes.
It's also easy to access if necessary when driving to override brake settings.
Old Nov 29, 2013 | 09:02 PM
ltng7679's Avatar
ltng7679
Location for Brake Controller - followup.
Alloro / Bob,
Thanks for the replies.
Bob - on my 2003 I don't see a fuse cover above the emergency brake. What year is your truck?
Ed
Old Nov 30, 2013 | 11:45 AM
alloro's Avatar
alloro
You don't have one on your 03. All of your interior fuses are instead over at the passenger kick panel.
Oh and BTW, many auto stores have the pigtail to plug into the factory brake controller harness. All you do is wire that pigtail to your controller and plug it in, mount the controller, and the job is done.
Old Dec 1, 2013 | 12:38 PM
r2millers's Avatar
r2millers
Alloro / Bob,
Ed
Ed,
Mines a 99 as noted in my signature. I wasn't aware of the changes made with your's.
That's why alloro helps keeps things straight.
Old Dec 1, 2013 | 12:44 PM
alloro's Avatar
alloro
Oh I make my share of mistakes. The changes between different model years and engine types leaves a lot of room for those pesky variables.
Old Dec 2, 2013 | 08:46 AM
broncoholic's Avatar
broncoholic
The brake controller on my 03 is mounted on the bottom of the dash above the driver's right leg. I'll try to remember to snap a pic when I get home today.
Old Dec 2, 2013 | 09:56 AM
alloro's Avatar
alloro
Of the controller or your leg?
Old Dec 3, 2013 | 04:53 PM
99expyTN's Avatar
99expyTN
Here are a couple of pictures of my brake controller. It is just to the right and below the steering wheel.
[IMG][/IMG]
[IMG][/IMG]
harley3348
All Things Towing
Mar 17, 2011 09:07 AM
bama210
Modular V10 (6.8l)
19
Mar 13, 2009 10:58 AM
snakebit
Jun 11, 2008 02:08 PM
