DEGREASER??????
Old Apr 17, 2014 | 01:00 PM
Dave145's Avatar
Dave145
Originally Posted by psychlopath
Gasoline actually works and is cheaper than anything else I've tried.
Any other petroleum based solvent is great as well; Mineral spirits works well, but is about 4x the price of gasoline. It isn't as volatile, so it wets an area longer.
I've tried all the colored cleaners and they dont seem to do much more than plain water for me.
A siphon sprayer is a great way to apply whatever you decide, without wasting a bunch of it and doubles as an air gun to help clean it all off after.
Here's a cheap one: Video Link: http://www.amazon.com/gp/product/B000COTXEI/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
You can also get 'em with long nozzles to help get into small areas.
Gas? Cheap? I wish I lived in your area then! Either way, cool tip.
Old Apr 17, 2014 | 03:40 PM
Bud Mud's Avatar
Bud Mud
so far the only thing working is the oven cleaner,i wont spray gas all over under my truck,thanks though. I also used 1 of my old paint gun's spraying thinner at high air pressure. THANKS again to all.
Old Apr 17, 2014 | 04:01 PM
-mywheels-'s Avatar
-mywheels-
I use a product called Citrol. Takes off oil and grease. It cleans gun barrels safely too! A local gunsmith soaks barrels in it overnight to remove old deposits. Takes gum out of carpets. Anyway, I use it on my trucks. Haven't had any problems. Plus it SMELLS good!
Old Apr 17, 2014 | 06:22 PM
trozei's Avatar
trozei
Find me a good degreaser that's less than $4 per gallon and I'll stock up.
Old Apr 17, 2014 | 06:29 PM
turbohunter's Avatar
turbohunter
I agree that the Purple crud works well but it leaves a white residue that pisses me off.
That said, I have a bottle of it in my garage.
I'd love to try some of the other stuff mentioned.
Old Apr 17, 2014 | 09:32 PM
psychlopath's Avatar
psychlopath
Gas? Cheap?
If you want to pay more, you can get premium. Or Avgas. They all work better than anything mentioned. Avgas is prettier, but regular ol' unleaded wont fail you either.
That whole "Not to be used as a solvent," rubbish is a warning from solvent companies.
Old Apr 17, 2014 | 09:36 PM
HIO Silver's Avatar
HIO Silver
Jet fuel, aka Avgas, is pretty much like kerosene.
Old Apr 18, 2014 | 12:41 AM
co425's Avatar
co425
I use kerosene. Great for motorcycle chains. I got a 55 gallon drum of aviation kero years ago for free. Haven't found a better solvent for that monkey turd grease build up on parts.
Old Apr 18, 2014 | 12:58 AM
fuzzybob's Avatar
fuzzybob
I like stoddard and a siphon gun.... finish it off with a pressure washer.
Old Apr 18, 2014 | 02:51 AM
Dave145's Avatar
Dave145
Gas here is 3.80 a gallon. Brake clean is 2 cans for $5. I dunno I was just sayin I wish gas was cheap enough to use for a large amount of degreaser.
Old Apr 18, 2014 | 04:00 AM
Bud Mud's Avatar
Bud Mud
where are you buying this at.
Old Apr 18, 2014 | 06:23 AM
psychlopath
Jet fuel isn't Avgas.
Avgas is leaded, high octane gasoline and goes into piston engines.
Jet fuel, on the other hand, goes into turbine engines.
Old Apr 18, 2014 | 08:48 AM
  #28
HIO Silver's Avatar
HIO Silver
Ok. ..whatever it is, it's pretty much like kerosene.
Old Apr 18, 2014 | 11:41 AM
  #29
-mywheels-'s Avatar
-mywheels-
I buy citrol through Tyco, my local Schaeffers oil distributor. You could also go to schaefferoil.com.
the_real_zekenator
Aug 4, 2019 07:41 PM
lupuseven
Apr 7, 2012 03:45 PM
ErrorS
13
Sep 30, 2007 09:40 PM
Dustin_86
16
Mar 3, 2006 12:57 AM
93XLT150
13
Mar 22, 2004 09:32 AM
