Best way to clean 30 yrs of grease?
Steam cleaner works the best
You should be able to find one in an truck related industrial area (if you live near one)
Put the front wheels up on ramps and take along a creeper or carpet.
For a homemade spray/stream cleaner I use a combination GUNK with Varsol cleaner.
Engine steam cleaner work the best and will cost the most.
Find the best car wash with good pressure. If you find a newly built car wash take it there, it will have all the latest pumps and some very good pressure at the nozzle. Alow the engine to cool down before you spray down the area with a good quality engine degreaser/cleaner and allow it to soak awhile. The start up the car wash in the soap mode. Some car washes have some fine engine degreaser / cleaners and do not require buying cans of engine degreaser / cleaner. Take home and scrap and wire brush the remaining areas.
________
_ Buck _
________
_ Buck _
well super clean is a good product but has only 10 % lye. 100% lye will eat grease fast. the hard part is is finding it. take a trip to your local hardware store and go to the drain opener isle. look for RED DEVIL brand lye. should be 5.00. that should make about 30 gallons of degreaser. I happened to find mine at the grocery store on the drain opener isle.
Originally Posted by bodian
Putty knife, alot of elbow grease, then the carwash
my mobile 18 horse diesel fired 300 degree 4000 psi 6 gpm hot water pressure washer does the trick...soak it with some dew brite degreaser at 300 degrees, then give it a good rinse with scalding hot water
forget scraping anything off
before i started my p-washing business i used elbow grease a garden hose and zep industrial cleaner
