Another push button start question :)
Old Apr 15, 2014 | 09:28 PM
450xracer68's Avatar
450xracer68
Hey guys I've been a lurker for quite some time here. Now before everybody gets mad... I have done just about every search on here and haven't had any luck yet..
I am building a offroad Truck that will be strictly used in the desert. I have a 1989 f150 5.0 2x4. I need to get rid of the steering column and ignition to run a different style column with quick release steering wheel.. now my main question is, what wires will I have to switch around in order to run just a power on switch and momentary push button? Dash is completly removed as of today and will be making a fiberglass one in place once my cage is done.
thanks for the help!
Old Apr 16, 2014 | 06:33 AM
Franklin2's Avatar
Franklin2
Make a list of the color of the wires going to the ignition switch. It was on top of the column, behind the dash. Going from memory;
Yellow wires are the hot wires from the battery
Red/blue-touch the yellow wire to the red/blue and it should crank unless your neutral start switch is not working.
There are a couple other wires there, one of them feeds the fuse box and one of them feeds the ignition coil. There are a couple others you probably don't need.
Steven Gatley Sr
Electrical Systems/Wiring
Jun 8, 2014 09:12 PM
bleedin'blue
Mar 3, 2011 12:12 AM
bleedin'blue
Mar 1, 2011 08:02 AM
RockbottomRanch
Jun 1, 2007 03:55 PM
flash-ah-ah
Sep 1, 2003 06:43 PM
