Does this sound about right?
Old Apr 14, 2014 | 11:25 AM
sjwelds's Avatar
sjwelds
So I have a 92 F350 4x4 LB with a flatbed. 7.3 ZF5 N/A Hypermax cowl induction afe power dryflow filter. IP and injectors recently rebuilt/replaced. Fuel turned up 1 flat or so. two-into-one 3.5" exhaust w/ free flow muffler. 285/75/16 tires on black painted steelies.
My question is this: I can hold 75 in OD as long as there isn't any headwind. Living in Central KS this doesn't happen all that often. If there's a headwind I can barely hold 65 or so in OD. I'm revving about 2k at 70. Does this sound about right for a N/A engine? I realize its a big heavy truck with no turbo was just gonna throw it out there for fellow N/A owners to comment on.
I know, I know, I need a turbo.......
Old Apr 14, 2014 | 02:22 PM
mu2bdriver's Avatar
mu2bdriver
At 70mph, I think I'm turning closer to 2300-2400RPM. I generally don't go faster than that so don't know about maintaining 75 or not.
Old Apr 14, 2014 | 02:32 PM
sjwelds's Avatar
sjwelds
yeah i think i must have 3:54 gears. I could just run in 4th gear but seems to be screaming fairly high...
Old Apr 14, 2014 | 03:47 PM
RA31925's Avatar
RA31925
Have you had your timing checked?
Old Apr 14, 2014 | 04:51 PM
sjwelds's Avatar
sjwelds
yeah when they installed the rebuilt IP...
Old Apr 14, 2014 | 08:30 PM
Redneckrucker16's Avatar
Redneckrucker16
I run 2200 RPMs doing 75mph and mines on 38in TSL swampers
Old Apr 14, 2014 | 08:43 PM
sjwelds's Avatar
sjwelds
what gear ratio do you have? must be low...have thought about swapping gears for a bit more power but it probably wouldn't make enough difference to be worth it.
Old Apr 14, 2014 | 09:28 PM
Macrobb's Avatar
Macrobb
Get yourself a turbo, man!
Seriously... especially with a turbo, those revs will be nice.
Old Apr 15, 2014 | 05:01 PM
sjwelds's Avatar
sjwelds
yeah well its not that easy to find a turbo...been looking around on eBay and craigslist...
also talked to my neighboring diesel mechanic who used to work at Ford back when they were installing turbos on these engines and he said that the na engines that he'd seen get turbos put on only lasted 30k miles or so till things were shot internally... hmmmm
Old Apr 15, 2014 | 05:21 PM
RA31925's Avatar
RA31925
They pop up every now and then on eBay. The challenge is the kits are almost never complete. Usually you will have to do some custom fab work, typically for the crossover pipe.
Either your mechanic has a bad memory or he doesn't know what he's talking about. The biggest risk of adding a turbo to an NA engine is a blown head gasket from running too much boost. I've never heard of someone adding a turbo and wearing out internals. What internals does he mean, anyway? Wrist pins?
...besides, if you're concerned about blowing your head gaskets, add ARP studs.
Old Apr 15, 2014 | 05:41 PM
sjwelds's Avatar
sjwelds
well as far as the fab work is concerned I'm a welder and fabricator by trade so that wouldn't be a problem in fact I built my own exhaust sys (SIG). but yeah I've read on here and obn how lots of guys run turbos on na engines with no problem. not sure what my mechanic means...
just wish I could find a turbo kit. maybe I should just order a new setup from Hypermax lol
chrisrevans
6.7L Power Stroke Diesel
May 10, 2018 05:54 PM
Syncrowave
Feb 21, 2016 04:56 PM
Goldenvoice
Apr 2, 2015 11:48 AM
Idaho Hillbilly
20
Dec 3, 2011 08:49 PM
johnn795
16
Nov 15, 2007 10:36 AM
