Tracking down an engine sound
Old May 9, 2018 | 07:34 PM
chrisrevans's Avatar
chrisrevans
2014 F250 6.7 short-bed 4x4 around 75K miles
Towed a travel trailer for the first time last week and noticed a new sound that I've probably dismissed before..
When going between 70-75mph under load the truck gives a groan / droan sound that resonates through the cab.. Go above or below this and it's gone. Not sure how else to describe it.. If I let off the pedal the sound goes away immediately.. It happens in 5th and 6th gear too, so it's not directly related to RPM. Now that I know what to listen for, it does exist when not towing too at the exact same speeds.
Rev'ing the engine to the same RPM's in other gears at different speeds doesn't give this result. It definitely sounds like it's in the engine bay/tranny area as it resonates through the cab. So I don't think it would be a differential or transfer case?
Could this possibly be the torque convertor when it's locked out? I'm not sure how to tell when the TC is even locked out to be honest..
Thanks in advance!
Old May 10, 2018 | 05:18 AM
senix's Avatar
senix
any chance you could record it? I am having a hard time trying to figure out what would make that aside from tires maybe. So you might start there with checking those pressures and adjusting then see if the sound goes away.
Old May 10, 2018 | 07:22 AM
chrisrevans
I can almost certainly say it's not the tires, they're new (Toyo AT). its something drive train related.. and as mentioned if I let off the pedal it immediately goes away.
At first I was wondering if it's something turbo related, but it happens whether psi is near 20 and also when it's at 10ish.. so that's where I'm thinking it might be transmission area..
Will try to see if I can record it.. will be hard since I'm not towing to have the sound happen for an extended period of time..
Thanks!
Old May 10, 2018 | 05:54 PM
Iowa Ford's Avatar
Iowa Ford
My 2012 does the same thing, only while pulling a load and making boost.
Always has been that way.
I have a farm tractor that does the same thing, at the right load.
I notice them both doing it every time I hear it, but pay no attention to it, I'm convinced it's normal.
I should add, I have hearing aids and it's the type of low tone sound I can hear easily, with or with out
the aids, when others don't hear it.
onug
2015 - 2020 F150
Apr 10, 2016 09:41 PM
SirArgus
1983 - 2012 Ranger & B-Series
Jun 15, 2012 08:58 AM
Jbrown8988
Mar 31, 2009 07:18 PM
flajoker
Jul 7, 2006 11:35 PM
Tptoe
Feb 16, 2004 06:51 PM
