vacuum questions
Old Apr 14, 2014 | 07:50 AM
BigNick98's Avatar
BigNick98
vacuum questions
Hey guys I noticed over the winter that my auto locking hubs wouldn't work and I had to manually lock them in. Not a big deal. But in winter I always keep my try truck on defrost and now that's it's getting hot no matter where I turn the **** it stays on defrost. Is this a related problem? Where should I look for vacuum lines to check? Or is it just a vacuum pump?
Old Apr 14, 2014 | 09:39 AM
HKusp's Avatar
HKusp
They are almost definitely related. The hubs have a yellow seal in them that can go bad and cause the exact symptoms that you are describing. Here is some good reading on the subject of the vacuum pump. It will help you diagnose.
https://www.ford-trucks.com/forums/1...cuum-pump.html
Here is a link to Guzzle's maintenance of the hubs themselves. It will give you a great idea what the innards of the ESOF hubs are all about. If they are the problem, you can replace some of the parts and be back up to spec.
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Apr 14, 2014 | 07:16 PM
F-250 Super Duty's Avatar
F-250 Super Duty
It may also be the stub axle vacuum seals. That's what was wrong with mine. Just replaced mine about two weeks ago. Not a bad job. Took about two hours to do both sides...
Old Apr 14, 2014 | 07:18 PM
BigNick98's Avatar
BigNick98
Cool thanks for the info guys, I'll start looking into it
Old Apr 15, 2014 | 05:51 AM
Tugly's Avatar
Tugly
...or it can just be cracked vacuum lines. My ESOF was easy to fix - lube hubs, fix bad vacuum lines, and replace the control solenoid... valve... what ever that thing on the passenger fender is called.
Old May 9, 2014 | 06:51 AM
BigNick98's Avatar
BigNick98
Still trying to figure this one out guys, where are the most common vacuum line leaks before I go buy a vacuum pump
Old May 9, 2014 | 07:16 AM
Tact's Avatar
Tact
Check each vacuum line going to each hub. You can disconnect them at the frame and use a vacuum hand pump to test each line. I would start there first. Over time these vacuum lines will deteriorate and cause a leak.
In the past I've also had issues with the axle knuckle seals leaking. I've replaced those as well.
Look at this vid:
Old May 9, 2014 | 10:49 PM
Walleye Hunter's Avatar
Walleye Hunter
Pull the line off your pump and hold a finger or thumb over the end. The pump should stop almost immediately. Then work your way through it one piece at a time. It's not as hard as it seems.
jimjokjv
Oct 5, 2018 05:02 PM
254XP3
Dec 13, 2017 08:14 AM
cowboylelle
Oct 12, 2010 08:05 AM
hammer65
Aug 12, 2010 06:30 PM
