clearance issues
Old Apr 13, 2014 | 09:43 AM
rockin300's Avatar
rockin300
clearance issues
Hi guys need to know how much of a lift i need to fit 36x12.50 tires under my 94 f150 i got just enough room in the rear but not the front
Old Apr 13, 2014 | 12:23 PM
Evan_P's Avatar
Evan_P
6" at a minimum.
Old Apr 13, 2014 | 09:47 PM
Michel153's Avatar
Michel153
once you start lifting that high remember that ttb front ends need to stay level so you don't wear out barring faster/ tire wear
Old Apr 13, 2014 | 10:52 PM
GNR22's Avatar
GNR22
Quite simply, don't do that. Your front end isn't going to like that at all. It's a general consensus here that 33" tires are about as big as you should go on those half ton TTB axles to avoid big problems and headaches.
Old Apr 13, 2014 | 11:02 PM
Evan_P's Avatar
Evan_P
This pretty much sums it up. The TTB is terrible with anything over 33's. I had 35's and all it did was east tires, ball joints and just about every other piece of the front end.
Extacie
Offroad & 4x4
31
Dec 7, 2012 01:53 PM
blshaf
Mar 18, 2011 09:11 AM
81fordf-250
Offroad & 4x4
38
Jan 21, 2009 02:00 PM
mobecker
1978 - 1996 Big Bronco
17
Dec 12, 2008 01:06 PM
gwwesch1983
Dec 9, 2003 05:08 PM
