Guys, my truck is down and dont know what's wrong.
It has been running great all winter, took it to the carwash
today and it died on the way home...stuck in a parking lot now
waiting for tow truck...sigh
I have good spark, getting fuel but yhe carb, Edelbrock 1406, will backfire ocassionally and it wont start
any ideas?
any recommendations for a mechanic in my area, Fedway or Tacoma?
What year and what engine?
Is it the Bronco in the signature?
[B][COLOR="SlateGray"]Sean [IMG]
Yes, had to tow it home.
Yes, same truck listed. 1979 400/C6.
I think that the timing chain has skipped a tooth..been through everything else I could think of..it all checks out. It wants to start but won't, sometimes get a backfire through the carb.
It's been so long. One other thing to check is the
distributor to see if it jumped. I would look there
before the timing chain. Just take the cap off and
double check that the rotor is pointing at #1 when
your at TDC. I think there is a slot on the rim under
the cap. Also make sure you at TDC on the compression
stroke. If you don't know what I am talking about let me
know and I can explain it. I don't assume that everyone
knows that.
