speedometer will only go to 40 ...???
I have an 03 f150 5.4, it runs fine, shifts fine and will get up to speed. I can go over 40 but the speedo will only work until i get to 40 and then it just stays there. My rpm guage seems to be working fine. ------i thought it might be the speed sensor/output sensor on the trans but it shifts fine so i dunno anymore.....???
Found one for you, post #2
https://www.ford-trucks.com/forums/1...-use-them.html
I think the procedure is the same from 1999-2003
Maybe someone else can confirm this
I tried doing that test already but the only thing that happens is it clicks over from the mileage to....Txx....such as T 54.7 dunno what that means but that is what it does. i assume its tied into the mileage cuz it continually goes up.--------unless im doing something wrong.
i bought a speed sensor or it might have another name....it goes on the tail end of the trans. I hesitated putting it on cuz the symptoms didnt quite seem all there. I will try it and post back, good or bad.
FORDF250HDXLT
02-26-2010 02:29 AM
