brake control install
Old Apr 10, 2014 | 08:28 PM
silverbullet13's Avatar
silverbullet13
I have a 2013 F150 CC with a 5.0 I have the harness that came with the truck it says to plug it in but the problem is there is no plug under the dash. All I found was a empty plug taped to a bunch of wires, it has the same end as the plug that came in the glove box can anyone shed some light on this? Thanks
Old Apr 10, 2014 | 11:36 PM
blueovelboy's Avatar
blueovelboy
pic would help but I think your saying its not there on the back of the cubby hole you took out. its taped to the obd2 port just under the dash. if its not that and you are talking about its not the right plug see if it has a adaptor on it that needs to be removed mine did.
Old Apr 11, 2014 | 06:39 PM
fastback89's Avatar
fastback89
The plug you found is probably the right one
It has a dummy cover on it that gets thrown out, just peel the tape back and pop it off. Your harness should then plug in..
Old Apr 11, 2014 | 08:32 PM
silverbullet13
I went to the dealer today and it took them about 30 min. but the tech found it behind the dash. the instructions I had said it was on the harness by the steering colum Im glad now the trailer won't push me around
Bergfurher
Jan 18, 2010 04:47 PM
mccann316
Oct 21, 2009 06:44 AM
tdgoss
All Things Towing
Dec 26, 2008 11:19 AM
Bootskillet
Feb 13, 2006 06:55 PM
redrum
1997 - 2003 F150
Nov 19, 2004 11:24 PM
