I do not have the manuel for my 02 SuperCrew and I need to hook up my Brake Controller, but do not have the Manuel and the owners guide tells me nothing, so I need some info from you guys
I have the Controller and the Wiring harness that goes from the Controller to the factor harness, but I am unsure which plug under the dash I am suppose to plug into, can you post a picture or tell me where I can get a picture on line that will help me out, Thanks alot
Brian
Look above your right knee. There should be a place to plug it in above your right knee area to the right of the steering column. The harness will plug straight up into it.
I am not sure thats exactly what I am looking for. I am new to Brake Controls...
Where does this Part go http://www.etrailer.com/Merchant2/me...tegory_Code=BC
does it splice into the wires coming out of the Controller and you just plug into the Gray mount under the Dash, or am I missing something
Thanks Brian
It plugs directly into the grey mating plug under the dash.The loose ends of the wires go to the controller. Does your truck have the 7 pin RV style receptical on the back under the bumper?
My truck has the 7 prong and the 4 prong light set up in the Rear
Ok, let me see if I have this right, from the Gray piece under the dash, I plug in the Harness that I posted, splice the 4 Wires all correct and than plug it into the Controller and Its all done after that...Brian
1 last question for you, I got the Tekonsha Voyager all wired up this morning, I went to mount it, but I have a Question for you, do I just screw the 6 "3/8"ths inch screws in to the side of the Controller to mount the Bracket....
Here is the diagram http://www.marksrv.com/9030manual.htm
yes, you actually screw the screws right into the side of the controller, through the plastic. Just make sure you use the supplied screws and only pierce the controller where its marked.
