how to remove the ac unit...
Old Apr 10, 2014 | 04:37 PM
C-AREVALO's Avatar
C-AREVALO
Hey guys I was wondering if theres a thread or if someone has removed the ac unit from the cab? I want to remove it cus I want a cleaner engine bay plus im not gonna use the ac since im gonna cut of the roof on my truck make it into a roadster type cab. Any help is really appreciated. Thanks in advance...
Old Apr 10, 2014 | 05:39 PM
C-AREVALO's Avatar
C-AREVALO
Anyone? ??
Old Apr 10, 2014 | 06:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There have been a few posts on the subject. Basically, other than removal, the 'biggie' is to fab a plate to cover the large hole left in the firewall from the removal of the evaporator housing. You can either make a plate that will bolt in place using the factory holes or fab a plate that gets welded in.
Everything else is pretty straight forward.
You can see in the picture, it's a pretty good sized hole.
Old Apr 10, 2014 | 06:10 PM
turbohunter's Avatar
turbohunter
Be very careful not to knock off the drain tube when you pull it out.
Recommend at least taking the hood off.
Go slow.
Here's where my rebuild starts.
https://www.ford-trucks.com/forums/1...did-it-14.html
Ranger73
Dec 29, 2006 09:04 PM
bucks77ford
18
Jun 16, 2006 09:07 AM
byerks
Jan 28, 2000 10:49 AM
