Block drain Q
Old Apr 10, 2014 | 02:32 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Block drain Q
Can the block be completely drained of coolant from the block heater? I know of the drain plugs on each side of the block. Just wondering if the block will completely drain there.
Thanks
Old Apr 10, 2014 | 03:13 PM
Pitcrw6's Avatar
Pitcrw6
There will be those high and low s pots and crevices that you won't be able to get it all out. But I wonder if you blow air through the degause bottle if you can get the rest of it out. Why are you wanting to completely drain the block?
Old Apr 10, 2014 | 03:26 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Been runing engine flush through it for the last week or two to get all the crap out from the cup replacement. just want to get as much as i can out before i put antifreeze back in.
Old Apr 10, 2014 | 03:34 PM
Pitcrw6's Avatar
Pitcrw6
Gotcha, I would think forced air from a leaf blower or shop vac might aid in getting it all out but I could be wrong.
Old Apr 10, 2014 | 03:39 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Thanks Pitcrew6, Iwill give it a shot.
Old Apr 10, 2014 | 10:19 PM
Bonanza35's Avatar
Bonanza35
With it out keep running good water threw it. That will flush as much as you can out of the system. It takes a lot but should do it.
Old Apr 11, 2014 | 08:39 AM
helifixer's Avatar
helifixer
the right side of the block will not drain from the heater port.
I put a flush T in the heater hose, remove the thermostat and let fresh water run through it flowing out the top of the degas bottle. when it gets clear I seal it up drive it a few miles and re-pete. after all the chemical / soap or whatever you used is gone than do a flush with distilled water and service with antifreeze.
Old Apr 11, 2014 | 09:13 AM
Tugly's Avatar
Tugly
Originally Posted by helifixer
the right side of the block will not drain from the heater port....
...but the passenger side of the engine block will drain. I used this method when draining for cup replacement.
Old Apr 11, 2014 | 12:13 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Thanks Rich, Gotter done yesterday, blew some air through the cooling system as well and got more water out too. Was kinda hoping you would chime in yesterday, thought i read some where you used this to drain the block.
bill wilson
Mar 8, 2015 01:51 PM
19tanker
23
Jan 20, 2014 08:54 AM
u.f.o
Nov 6, 2009 04:04 PM
ealbertson
Apr 2, 2006 07:30 PM
Ed
Aerostar
Jun 13, 2005 08:35 PM
