dipsticks
Old Apr 10, 2014 | 01:23 PM
wlittle's Avatar
wlittle
dipsticks
Hello all, I am in need of some clarification. I am in Alberta and seemed to have misplaced both my dipsticks for the power steering pump and my c-6 transmission. The power steering dipstick is the actual dipstick not the cap. Any ideas where I could get these from. Would any transmission dipstick work from a c-6? So close to getting my truck back on the road, but can't do it without these. Thanks in advance.
Old Apr 10, 2014 | 01:40 PM
choptop49ford's Avatar
choptop49ford
As far as I know the only variation on the C6 dipstick is the extra long one used on econolines, it goes clear up to the front of the engine. As far as the power steering dipstick, if it is like this one, you will probably have a little harder time finding one.
Old Apr 10, 2014 | 02:37 PM
hickory1991's Avatar
hickory1991
I've seen the power steering dipsticks for sale before. Can't remember for sure but try either NPD or LMC. Not sure on the trans dipstick.
Old Apr 10, 2014 | 03:53 PM
wlittle's Avatar
wlittle
Thanks guys, that does help. I do have the pump like in the picture. Just not sure, but will see if PartSource or Napa can order them in.
Old Apr 10, 2014 | 07:42 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
EZ to find in junkyards.
D6AZ-3A006-B (replaced C7AZ-3A006-A; D1VY-3A006-A & D6AZ-3A006-A) .. P/S Pump Dipstick-Steel w/a crooked handle / Use with Ford P/S Pump with steel reservoir / Obsolete
1967/77 all FoMoCo Passenger Cars / 1967/77 F100/350 / 1969/74 Econoline / 1973/77 Bronco.
Not the same P/S pump dipsticks:
Saginaw P/S pump (resembles a ("canned ham") used on 1972/79 Passenger Cars with Hydro-Boost & 1975/91 Econolines.
1978 and later Ford P/S pumps have a plastic reservoir. The dipstick is also plastic and is much larger in diameter than the 1967/77 D6AZ-3A006-B steel dipstick.
Old Apr 10, 2014 | 07:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
LMC carries the P/S dipstick in both painted and chrome versions for the original style, expensive at $18.95 painted or $24.95 chrome, they also have a replacement thats $6.95
They also have a stainless steel C6 dipstick but at $54.95, I would look for a stock replacement.
Old Apr 10, 2014 | 08:35 PM
choptop49ford
My bad. Wasn't sure how recent they were in use. Around here you aren't allowed into any of the salvage yards any more, you have to tell them specifically what you want and if they have it then they pull it and bring it to the counter for you. Even if you could go in they don't keep anything older than the LATE 90's at best. Around here rust is so bad that 80's models on the road are getting scarce and something like dent sides, especially in good shape are rare as hens teeth.
Old Apr 11, 2014 | 07:11 AM
NumberDummy
Originally Posted by wlittle
I am in Alberta and seemed to have misplaced both my dipsticks for the power steering pump and my C6 transmission.
Would any transmission dipstick work from a C6?
No, absolutely not!
What year is the truck? If it's a 1978 or 1979, what is the engine size?
1973/79 F100/350: FIVE different C6 dipsticks!
Old Apr 11, 2014 | 07:51 AM
wlittle's Avatar
wlittle
Thanks again guys. I only want to order locally as I tried LMC once and the shipping was crazy. The truck is a 1977 f-150 custom witha 351m. The power steering is from a 1976 f-150. Really tight budget here and not finding any "parts trucks" of those years around here. Again, I appreciate your help.
Old Apr 11, 2014 | 08:10 AM
NumberDummy
The truck is a 1977 F150 w/a 351M/C6
D7TZ-7A020-B .. C6 Dipstick / Stamped with ID number: D7TP-7A020-DA or D7TP-DA / Obsolete
Applications: 1977/79 F100/350 351M/400/460 & 1978/79 Bronco 351M/400.
TOM HILLIER FORD in Escalon CA has ONE = 209-838-4155.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
YADKIN VALLEY MOTOR CO. in North Wilkesboro NC has ONE = 336-838-4155.
PLEASANTVILLE FORD in Pleasantville NY has ONE = 914-769-1800.
MILLER OBSOLETE PARTS in Binghamton NY has TWO = 607-722-5371.
There's a guy in Innisfail AB that may have both dipsticks. Send me an email: sylhall@aol.com and I'll pass along his name and email address.
articphoto
Jul 20, 2008 11:10 PM
m thatcher
Bronco II
Jan 6, 2006 06:55 PM
benwantland
Sep 9, 2003 07:36 PM
Stanstruck
Bronco II
Aug 29, 2003 10:50 AM
bobj49f2
Oct 20, 2002 10:31 PM
