Help ID this alternator
Old Apr 10, 2014 | 09:51 AM
bigcrunch's Avatar
bigcrunch
It is on my 93 F350 - 460 not original, looks to be 3g with threaded upper hole. What did it come off??? I need to find and identical.
<a href="http://s307.photobucket.com/user/bigcrunch69/media/F3504x4460/100_1505.jpg.html" target="_blank"><img src="http://i307.photobucket.com/albums/nn315/bigcrunch69/F3504x4460/100_1505.jpg" border="0" alt=" photo 100_1505.jpg"/></a>
<a href="http://s307.photobucket.com/user/bigcrunch69/media/F3504x4460/100_1504.jpg.html" target="_blank"><img src="http://i307.photobucket.com/albums/nn315/bigcrunch69/F3504x4460/100_1504.jpg" border="0" alt=" photo 100_1504.jpg"/></a>
<a href="http://s307.photobucket.com/user/bigcrunch69/media/F3504x4460/100_1503.jpg.html" target="_blank"><img src="http://i307.photobucket.com/albums/nn315/bigcrunch69/F3504x4460/100_1503.jpg" border="0" alt="1993 f350 460 photo 100_1503.jpg"/></a>
thanks,
Old Apr 10, 2014 | 10:39 AM
dixie460's Avatar
dixie460
Not sure what it came off it, but at best it's rated for 95 amps peak output.
If that was on there before, you should just get a 130A unit and bolt that in instead since you know it'll fit.
Old Apr 10, 2014 | 10:45 AM
MR KROGOTH's Avatar
MR KROGOTH
That is a 95A 3G alternator, 180* ear orientation, 7.5" hole spacing.
92-94 3.0L Aerostar (early 92s were 2G not 3G, so check before you buy)
96-97 F series pickup with a 7.5L
Old Apr 10, 2014 | 11:17 AM
RIKIL's Avatar
RIKIL
Why do you think that? It's a 3G alternator, possibly a 3G/4G hybrid, and I don't see anything on there that indicates output amps.
Mine looks exactly the same and is rated for 250 amps.
Old Apr 10, 2014 | 11:38 AM
dixie460's Avatar
dixie460
Look between the webbing on the front of the case... there are 4 ventilation holes.
Those are only rated for 95A, some were rated less.
If it were to have 2 (larger) holes it would be the 130A model.
Look here:
How to tell if a 3G Alternator is 130 Amp? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old Apr 10, 2014 | 12:40 PM
bigcrunch's Avatar
bigcrunch
I looked at Rockauto for
looks same plug has dif orientation I'll see if local P A L has any. thank,s
1973supercamper
Mar 24, 2016 07:28 AM
Smirks90
Nov 3, 2014 09:58 PM
schoo
May 26, 2013 08:56 AM
denman81
Oct 8, 2007 05:26 AM
