Dual pump issue.
Old Apr 8, 2014 | 09:46 PM
ROBBINthaHOOD's Avatar
ROBBINthaHOOD
Dual pump issue.
On my dads 95 F150 (5.0) the front pump is pumping fuel out the neck under the filler cap while having the rear pump switched on. It quits coming out the neck when switched to the front and drives fine. Any ideas? Thanks.
Old Apr 8, 2014 | 09:59 PM
eakermeld's Avatar
eakermeld
Actually the REAR pump is pumping fuel out the front tank because the check valves in the front tank have gone bad.
Old Apr 8, 2014 | 10:01 PM
eakermeld's Avatar
eakermeld
Excuse me, because the check valves in the front PUMP have gone bad...........
Old Apr 8, 2014 | 10:38 PM
ROBBINthaHOOD
Did it quit leaking due to the tank being low as they were full when it started.
Old Apr 8, 2014 | 11:19 PM
r.a.ott's Avatar
r.a.ott
dual tanks
It's possible to fill both tanks but you must use the front tank first. When you switch to the rear tank it will pump fuel to the engine but any unused fuel will return to the front tank due to the faulty check valve in the front tank fuel delivery pump. If you are on the rear tank there must be room in the front tank to take any unused returning fuel. I have the same situation and am debating whether to replace the front pump or just go with what I suggested above. This information was obtained via searches on this website. I believe I stated this accurately but I am new here and have very limited mechanical experience or skill. Hope this helps. Rob
Old Apr 8, 2014 | 11:27 PM
ROBBINthaHOOD
Thanks to both of you. Will probably tear into it this weekend.
JetMech07
Jun 17, 2012 03:40 PM
F150-4-Life
24
Jun 6, 2010 09:15 PM
guitarnik
Mar 17, 2008 07:14 PM
moose94
Jul 19, 2004 12:18 PM
dwpenney
Jan 8, 2001 10:24 PM
