fuel pump q's
Old Mar 17, 2008 | 05:49 PM
guitarnik's Avatar
guitarnik
fuel pump q's
How many volts does it take to run the fuel pump?
guitarnik's Avatar
guitarnik
on a 1990 f250 with a 351w , sorry
Old Mar 17, 2008 | 06:35 PM
kcb37's Avatar
kcb37
How many volts do you have?
Should be 12v.
Do you have dual tanks?
If so see how much you have to the front and rear tank, then how much you have to the high pressure pump.
Old Mar 17, 2008 | 07:14 PM
guitarnik's Avatar
guitarnik
i have the dual setup minus the rear tank and pump, what is the high pressure pump. i thought each tank had a seperate pump.
