Timing gear fun.
Old Apr 8, 2014 | 09:24 PM
Jonathan Page's Avatar
Jonathan Page
Timing gear fun.
If you ever have to replace your timing gears on a 4.9 liter and you go with the steel gears instead of the other fiber gears you may have some fun sounds when you first start her up. As long as you've done everything right than have no fear. I just replaced mine on my 82 F100 and went through hell trying to find out what the sound was. After ALOT of research I found out that even the tiniest little nick or burr will transfer quite a bit of noise. So i put everything back together for the third time and just let her run for about 10 mins. The sound slowly started to dissipate. So I hope this helps somebody who is going crazy over that damn sound.
Old Apr 9, 2014 | 07:43 AM
bruno2's Avatar
bruno2
I think the reason the ran the fibers gears was for noise reduction. Steel gears make noise.
Old Apr 9, 2014 | 08:20 AM
billt28's Avatar
billt28
That's exactly why they stopped using the metal timing gears. I put a set of cloys in my 4.9, and haven't really noticed any difference.
Old Apr 9, 2014 | 06:17 PM
maytag906's Avatar
maytag906
I changed out a set of fiber gears in an 86 4.9 years ago. Installed steel gears.
Darn thing had a whine like a 6:71 blower!
Old Yblockman
May 17, 2017 02:18 PM
tonfro
Oct 28, 2007 09:50 AM
Gatsby
17
Jan 8, 2005 08:42 PM
mick460
Aug 20, 2002 08:13 PM
Torky
Nov 20, 2001 04:17 PM
