5.0L balancer ???
Old Apr 11, 2006 | 04:26 PM
raceman712's Avatar
raceman712
5.0L balancer ???
I've got a 96' F-150 that i'm building a 331 stroker for and i always see internal and external balance, and also 28oz and 50oz. How do i know what balancer i need?? (crank, rods and pistons are being balenced by the machine shop)
Old Apr 12, 2006 | 09:46 PM
12secondstang's Avatar
12secondstang
Any stroker that I have seen uses a Zero or 28oz balance. If 28oz. you will need a 28oz. Balancer and a 28oz. Flywheel. If not it will shake and vibrate real bad and quickly tear up the bottom end on you.
Old Apr 13, 2006 | 09:59 AM
gustang818's Avatar
gustang818
You might want to contact the manufacturer/distributor of your stroker crank to ask what balance they use and get the appropriate balancer/flywheel.
Old Apr 14, 2006 | 10:25 PM
Muldo's Avatar
Muldo
I just went through this with a stroker kit I got from Ford Performance Solutions. It was specifically set up for a 28 oz balancer/flexplate combo.
I can be a little more helpfull if I know what transmission you're running.
Mike
bootie
Aug 12, 2005 08:12 PM
Shernius
Jun 24, 2005 03:59 PM
bron1967
Oct 23, 2004 10:45 PM
fordman300
Sep 13, 2004 04:40 PM
tHeCoS
1978 - 1996 Big Bronco
Jan 11, 2004 06:05 AM
