Oil & Lubrication
Oil filter magnets?
Old Oct 13, 2003 | 09:31 PM
BigMattXXL's Avatar
BigMattXXL
Question Oil filter magnets?
Whaddya guys think? I've been seeing those magnets you stick onto the end of the filter to trap small metal particles inside of it. Sounds like a good idea, but is there any merit to the claims?
XXL
Old Oct 13, 2003 | 09:41 PM
c_rossman's Avatar
c_rossman
I would go with a magnetic drain plug before a filter magnet. With the filter magnet, The metal shavings have already gone thru the oil pump causing wear. I believe a good filter should catch anything that is big enough to cause any harm.
Old Oct 14, 2003 | 06:58 AM
chevdog's Avatar
chevdog
I have used rare-earth magnets for years on both the end of the oil filter and on the bottom of steel oil and transmission pans. The magnetic drain plug is also a great idea.
I prefer the disc type magnets, about 1/2" diameter by 1/8" thick. They are amazingly strong.
Here's a link to an example of what I'm talking about.
When I change the oil, I remove the magnets from the filter and pan, then stick them back on after the oil change. You will need a small screwdriver to help pry them off!
1994F2507.3L
Aug 16, 2014 10:33 PM
rvf62
Jul 9, 2014 09:04 AM
clem1226
All Things Towing
May 6, 2014 09:54 AM
joe blow
Dec 11, 2013 03:53 PM
GHeTTo JOe
Mar 16, 2011 10:52 AM
