6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Needing some assistance.
Old 04-07-2014, 05:40 PM
POXYSCHMOOT's Avatar
POXYSCHMOOT
POXYSCHMOOT is offline
Hi all, first time on the forums but they look pretty helpful so I figured this would be worth a shot.
I just recently bought my 08 6.4 and am fairly new to diesels in general, but I had a completely broken (in half) EGR OC pipe. I have gotten it all unbolted, and the bottom half of the pipe out, but cannot get the rest of it. I'm trying to do all of this without lifting the cab, due to not having the experience or the equipment, but everything is really trying to push me in that direction.
I'm really just wanting some input on this whole situation. I have a new pipe sitting here already just need to figure out how to replace it. And also if it would be possible to lift the cab up just a few inches without having to disconnect everything.
Thank you,
Mike
Old 04-07-2014, 07:21 PM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
Are you talking about the EGR coolers? If you have the lower off then the top one or vertical cooler should be a breeze.
Old 04-07-2014, 07:59 PM
POXYSCHMOOT
Its not the cooler, its the pipe that comes out of the drivers side bottom cooler and connects to the up pipes. I can try to find a good picture of it and post it if necessary.
Old 04-07-2014, 08:02 PM
senix's Avatar
senix
senix is offline
Now I understand. Some have had luck with just taking the cab bolts loose and using some jacks and just lifting a few inches.
Use some 2x4's between the frame and cab.
Old 04-07-2014, 08:03 PM
POXYSCHMOOT
http://imgur.com/9ufW3wY
Hope this clarifies things.
Old 04-07-2014, 08:05 PM
POXYSCHMOOT
Can I actually do that without having to disconnect everything, draining all fluids, and such??
Old 04-07-2014, 08:08 PM
senix's Avatar
senix
senix is offline
Yeah there should be enough room to give you a few inches.
Disconnect batteries, take the air box out and I think there is enough then.
May need to disconnect the wiring harness right behind the air box.
Old 04-07-2014, 08:12 PM
POXYSCHMOOT
Would i have to jack up both sides at the same time? Or could I get away with just unbolting them all and raising that corner slightly? Sorry to be dragging this out, I'm just trying to do this without causing an even larger issue :P
Old 04-07-2014, 08:18 PM
senix's Avatar
senix
senix is offline
Get some boards. Work your way around all four corners of the cab. Raise a little, insert board, move to next one and so on.
You only need a few inches I am sure to get to the pipe. So not much.
but remove all the bolts before you start.
Old 04-07-2014, 08:22 PM
POXYSCHMOOT
Alrighty! Will for sure be trying this tomorrow, thanks a ton for the help!
autonoz
09-01-2011 03:18 PM
King Rancher
11-05-2010 06:59 PM
badbrad60
02-25-2008 11:32 PM
denman81
10-23-2007 03:26 PM
mulot30th
08-26-2006 12:45 PM
Quick Reply: Needing some assistance.
