Today I began (will finish tomorrow) my 4" magnaflow catback installation and while at it I decided to permanently disable my EGR. So I removed the up-pipe and completely cutted the EGR cooler exit and completely removed the "yikes" cup inside the up pipe that lead to egr cooler. Then I got it welded and it now look like a normal pipe and made a cap to block off the egr cooler from exterior air.
Then I noticed the egr cooler pipe split to a smaller pipe that goes into the center of the engine block. Is this some kind of check valve that act as PCV?
