Lost power steering and power breaks!??
I have a 2008 F350 6.4ltr
I was just rolling up to a stop sign and lost my power steering and power breaks! I quickly pulled over and opened the good thinking I lost my serpentine belt. Everything looked fine, jumped back in my truck and everything was working again??
Anyone have any suggestions what caused this??
Your power steering pump may be failing. As sxrfun states, check your power steering fluid. Your brakes and steering use the power steering pump for power. Somewhere along the line you lost pressure. Either the pump failed to build pressure due to low fluid level, there is a valve of some sort sticking, or it went past a seal or hose. Check for visual leaks.
Ok, I checked the fluid level, it is low a little bit. I'm gonna add more to it today, what type of fluid is called for the power steering?
The fluid also has never bin changed. Can this be flushed by a shop or is there an easy way that I can do it myself?
I can't find any visible leaks either.
crashed13
21
10-03-2005 03:56 PM
