Sponsored by: Auxito
LF Door Power window?
Old Apr 17, 2014 | 01:31 AM
  #31
Jim98F150's Avatar
Jim98F150
Originally Posted by BFTUFF
Well my new parts are on the way and will get installed as soon as the weather and time permit: Reman. Motorcraft motor, New Motorcraft regulator, New Motorcraft window run channel molding. I hope that does the trick.
well, good luck with it. I hope it does the trick
Old Apr 17, 2014 | 03:01 AM
  #32
BFTUFF's Avatar
BFTUFF
The window run molding is an overlooked problem that makes the other parts fail due to extreme drag if not all out stoppage of the windows up and down movement. I told my brother about it and he has the same problem with his 91' Toy Camry. If the problem is diagnosed early and correctly it will save the cost of replacing the other parts and add longevity to the whole power windows operation.
Old Apr 17, 2014 | 03:53 AM
  #33
Jim98F150's Avatar
Jim98F150
I'll bet that's true..
I have the motor out right now, and I put the window up and down manually these days. That track (run channel) has some sticky spots for sure!
Old Apr 18, 2014 | 01:18 AM
  #34
BFTUFF's Avatar
BFTUFF
My new motor just arrived today and the regulator soon. We also got 7+ inches of snow over night so I will likely not get into the door for some time; weeks or longer as we still have loads of snow up here in Northern MN. I'm just keeping it closed for the most part.
Old Apr 26, 2014 | 05:23 AM
  #35
BFTUFF's Avatar
BFTUFF
Reading other posts, I found out that the regulator motor has a *thermal resistor built in that stops the operation of the motor if it bottoms out and the button is still being pushed. Visa-versa also if the window tops out in the door to keep the motor from overheating. The *TR can fail by itself and cause intermittent operation of the power window. Just replace the motor assembly and regulator because all those parts have wear points that slowly degrade and cause problems.
Now I'm trying to find out what size bolts to attach the new regulator to the door with once the rivets have been drilled out. My new regulator came and no bolts or rivets were included with the New Motorcraft regulator. I don't think I'll have to drill out the motor detents in the door if I remove the regulator with the motor still attached and replace it the same way.
Old Apr 26, 2014 | 06:00 AM
  #36
Jim98F150's Avatar
Jim98F150
iirc, you'll want 1/4" bolts to replace the rivets. If you put star washers on the inside, you can tighten them from the "easy side", without having to put a wrench inside the door.
I can't remember if it was 1/4" or 3/16" bolts though...
Old Apr 27, 2014 | 04:24 AM
  #37
BFTUFF's Avatar
BFTUFF
Another tip from the video: You can put some adhesive on the nuts that go on the regulator to make the installation easier to get started. I'll probably use grade 5 flanged lock nuts and bolts if I can find them.
Rich G
Apr 22, 2017 09:51 PM
Fuha
Feb 11, 2012 10:52 PM
krehjc
Paint & Bodywork
Jun 14, 2011 05:42 PM
wiskyseria
Nov 8, 2004 11:01 AM
WXboy
1983 - 2012 Ranger & B-Series
May 1, 2003 08:23 PM
