Swapping doors
Old Apr 6, 2014 | 07:44 PM
nintey4f150's Avatar
nintey4f150
Swapping doors
I picked up a set of power doors for my truck. I currently have power doors.. Wondering where everything unplugs .. The doors I picked up only has a wire coming off the window motor I believe and they cut it.. Just wanna see what's involved before I get into it
Old Apr 7, 2014 | 04:41 AM
Diesel_Brad's Avatar
Diesel_Brad
HA. Good luck. The drivers door has the the WHOLE harness that runs all the way across the BACK of the dash and has plug at the passenger kick panel. It is a real project
Old Apr 7, 2014 | 08:04 AM
nintey4f150
Yea I do know that and I have found out that I can just unplug everything inside of the door and pull the wires out where they go in so I don't think it will be that bad
Old Apr 7, 2014 | 08:41 AM
Conanski's Avatar
Conanski
That's what I did when I swapped doors on my '90 a few years ago.. went pretty easy.
Old Apr 7, 2014 | 09:30 AM
nintey4f150
Cool.. Any tips for pulling off the fenders too? I also got a set of fenders
Old Apr 7, 2014 | 10:35 AM
Conanski's Avatar
Conanski
Easier to swap fenders with the doors off but then you have no reference for alignment so maybe put the doors on and get it lined up with the old fenders first, you just need an extension to get to one of the fender bolts in the door jam after that.
Everthing along the sides and front of the engine bay is attached to the fenders, so you will need to remove the grill, headlights, battery and tray, and airbox, and then remove bolts and screws connecting the fenders to the rad support, front trim below grill and headlights, inner fenders, and the cab(3 bolts 1 top, 1 middle between door hinges, 1 bottom.
BWD444
Jul 8, 2017 06:19 PM
aoh1148
Nov 27, 2012 07:46 AM
eatfish
Feb 12, 2012 12:42 PM
bobbyt89
Apr 27, 2011 10:58 PM
jrodimus
Jan 17, 2010 03:41 PM
