Found It!
Old Apr 5, 2014 | 09:11 PM
reamer's Avatar
reamer
Found It!
Smallblock ZF 4x4, $400 Part No E8TA7003 ZB, S 5-42
Old Apr 5, 2014 | 09:20 PM
Gary Lewis's Avatar
Gary Lewis
Not a bad price. Did you buy it?
Old Apr 5, 2014 | 09:56 PM
reamer's Avatar
reamer
Got him down to $350. Promises it does not need a rebuild, slave is fine.
will get it tomorrow.
the coupling between the NP435 and the T-case, that is a direct fit to the ZF too?
Old Apr 5, 2014 | 10:07 PM
Rogue_Wulff's Avatar
Rogue_Wulff
TC should bolt up to the ZF. Ford used the same mounting pattern right up till the ZF6.....
$350 isn't too bad a price, if the trans is in decent condition.
You should be able to get a later hydraulic line, and hook it up to the current master, as well the slave. I would highly advise going with a new slave, since the trans has to come out to replace it......
Old Apr 5, 2014 | 10:08 PM
Gary Lewis's Avatar
Gary Lewis
Yep. That's one of the few things Ford didn't change. So your t-case will bolt right on. Score!
Old Apr 5, 2014 | 10:50 PM
bruno2's Avatar
bruno2
New slave. The small block ZF's are internal.You don't want to have to pull it back out to change it.
Old Apr 6, 2014 | 06:52 AM
reamer's Avatar
reamer
Who seems to have the "better" slave valves?
and auto zone?
a NAPA?
or don't mess with them and go Ford dealership?
Old Apr 6, 2014 | 07:12 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by reamer
Smallblock ZF 4x4, $400 Part No E8TA-7003-ZB
1988/89 F150/250 & Bronco 4.9L & 5.8L 4WD
Old Apr 6, 2014 | 08:23 AM
Gary Lewis's Avatar
Gary Lewis
Make sure you get the shift lever and, hopefully, the transmission cover as the stock one won't clear the ZF.
Old Apr 6, 2014 | 08:46 AM
bruno2's Avatar
bruno2
I wouldn't go vatozone. Napa or Ford for sure. I have had decent luck with the O'Reilly stuff too.
Old Apr 6, 2014 | 08:58 AM
Sw1tchfoot's Avatar
Sw1tchfoot
Not bad, I paid $350 for a 2wd ZF5.
I bought a slave cylinder from OReilly's to not chance it with the old slave, and the new one went bad. I never did anything other than push in the clutch a few times as it set a couple months. I got a warranty replacement on that one and so far it has been okay.. but I am almost sure that Autozone sells the same thing in the "Duralast" box. If you want to do some investigating you could go to NAPA/OReilly's/Autozone and ask to see the part, I bet they will all be the same. I have even heard of the ones from the dealer having the same logo on them but cannot confirm.
this is the only other style I know of and I do not know about the reliability:
EffunFiddy
39
Dec 28, 2022 03:05 PM
roadrash63
Aug 31, 2015 08:26 PM
FahrtAutoRC
Jun 24, 2014 01:11 PM
Molineguy
Jun 12, 2010 07:09 AM
Ukraine Train
Dec 6, 2004 03:34 PM
