Engine Cover Fitment
Old Apr 2, 2014 | 08:11 PM
HAMMERDOWN103's Avatar
HAMMERDOWN103
Bought a brand new cover from the dealer, black plastic piece that says Powerstroke and goes in front of the fuel bowl, and it bumps up against the ac compressor. Is this normal or am I supposed to trim it? Is it possible they gave me one for a 6.0? Seems odd they could screw this up ....
Old Apr 2, 2014 | 08:17 PM
Supercab's Avatar
Supercab
Any way you could post a picture of the situation?
Old Apr 2, 2014 | 09:28 PM
t.scottNDU's Avatar
t.scottNDU
I might be captain obvious here, but personally I've found that the '00 cover won't fit on my '03, and vice versa IIRC. Maybe you just got the later model cover?
Old Apr 3, 2014 | 03:09 AM
Stewart_H's Avatar
Stewart_H
Which one does it look like?
This one....
...or this one....
Stewart
Old Apr 3, 2014 | 03:15 AM
BigAlsPSD's Avatar
BigAlsPSD
6.0 doesn't have one that mounts atop the hpop reservoir.
The 99 models were different than 00+ though as Stewart is pointing out.
Your bracket could just be bent too...
Old Apr 3, 2014 | 05:45 AM
Supercab's Avatar
Supercab
WOW!! I had NO idea that there was a second version for 7.3s
I have a LATE '99 and mine is the one in the first picture.
I wonder when the chance happened build date wise?
Whats different in the area from '99 to '00 to need this change?
Old Apr 3, 2014 | 07:20 AM
HKusp's Avatar
HKusp
Hmmmm, I already learned something today. I guess I can go back to sleep...
Old Apr 3, 2014 | 09:00 AM
HAMMERDOWN103
Well crap .... The one that they gave me that does not fit is the second picture. I believe my trucks build date is 10/00 so it probably used the last of those ones .... I have no problem modifying the one I bought but trying to make everything under the hood appear factory so I would prefer not to. Seems odd that they would change that if the motor and everything else is the same. And it begins .....
Old Apr 3, 2014 | 09:49 AM
clem1226's Avatar
clem1226
Wasn't there also a third version/later version that had a door in it so you could change the fuel filter without removing it?
Old Apr 3, 2014 | 11:11 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The "third" version (as well as the fourth!) were actually EARLIER versions (with the flip up lid) that were larger and covered up more of the top. They were for the 94-97 model years that had the different fuel pump system.
With each successive redesign, the cover got smaller and smaller.
The final design, from 2001 to 2003, is the second picture of the two images above, that only says "POWER STROKE". All of the previous versions have more writing, like 7.3 Liter etc.
In either late 2001 or early 2001 I placed an order for a replacement engine cover for my 2000 model year which looks like the first picture, and the cover that looks like the second picture was shipped to me, with NO CHANGE IN PART NUMBER! There was no superseded suffix at the end, such as "AA" to "AB". Just a new cover that didn't match. So, I decided not to modify my original cover as previously planned, because even as early as back then, I would not be able to replace it through Ford.
If this was the case over a decade ago, then it stands to reason that it remains the case today. However, Bonanza 35 has posted below that he was able to get one last year... the same one I tried to get 10 years earlier. So I had to go back and edit this post to correct my assumption that the earlier ones were no longer available through Ford.
I'm actually looking for another new style engine cover like the one you received (not for my engine).
Old Apr 3, 2014 | 03:25 PM
HAMMERDOWN103
Problem solved. Returning the plastic cover and for $20 more getting a nice SS from Dfuser. Looks way nicer and will dress up the whole area .... And if it happens to hide a few other modifications that may or may not be there then cool
Old Apr 3, 2014 | 03:36 PM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
I actually have the 5TH version, which I prefer to all the others, which is none.
Old Apr 3, 2014 | 07:26 PM
Bonanza35's Avatar
Bonanza35
Ford has not sold the engine cover in the first picture in over 10 years. In fact, in either late 2001 or early 2001 I placed an order for a replacement engine cover for my 2000 model year which looks like the first picture, and the cover that looks like the second picture was shipped to me, with NO CHANGE IN PART NUMBER! There was no superseded suffix at the end, such as "AA" to "AB". Just a new cover that didn't match. So, I decided not to modify my original cover as previously planned, because even as early as back then, I would not be able to replace it through Ford.
If this was the case over a decade ago, then it stands to reason that it remains the case today. If you want the original as built engine cover, you will have to look for a used one (that isn't cracked, painted red, drilled through, etc) for a 1999 - 2001, which includes the early 99's built in 1998.
I hate to say your wrong because I like your posts but I bought the first picture last year from ford. The part number is#F81A 6A949AB. I haven't even installed it yet so I have it in my hand. The last one was broke by a fool who was suppost to be resealing my Diff. What he was doing up there I don't know. Anyway I just thought I would post this guys.
Old Apr 3, 2014 | 07:40 PM
Firefighter 1406's Avatar
Firefighter 1406
I am thinking about trading in my 1st picture one for a 2nd picture one.
Old Apr 3, 2014 | 07:44 PM
guitarpicr's Avatar
guitarpicr
Thats my preference also - Makes it easy to change the filter
