On my stock 6-volt positive ground system, the wire from my ignition switch goes directly to the coil; is this correct or should there be a resistor? Then again, the coil my have an internal resistor. I'm just not sure. Thanks. Steve
does your distributor require a ballast resistor in line from ignition switch ---> coil? If your engine has been running fine, then no you do not require a resistor. otherwise your ignition module would've eventually destructed by now...
Also, check your starter solenoid, you may actually have a resistor bypass wire, running to the coil, meaning you'd also have a loom resistance wire from switch to coil. so no, probably not.
I don't think you can say whether one is needed or not unless you know what coil is in it. Some 6v Fords used resistors, trucks generally did not. But the chances it has an original coil are slim. If you aren't having problems, leave it alone.
You are correct. Someone could have installed the incorrect coil at some point Since his truck was originally equipped with a 6 volt coil I assumed that is what he has. As we all know this is not always the case.
Steve, if someone mistakenly installed a 3 volt coil (unlikely), the best course would be to install the correct 6 volt such as this one from NAPA. You will not need a resistor with a original or correct replacement coil. NAPA AUTO PARTS
Thanks however I do have a 6-volt coil that I purchased at Auto Zone. Cold starts are quick but sometimes it takes several engine rotations before firing-up when it is hot. The main reason I was asking about the resistor was that if there was a resistor in the circuit, I was thinking about running a bypass from the starter cable connection on the starter solenoid to the coil with a diode in between. This way the coil would be receiving a full 6 volts during warm start-ups and may improve quicker starts. Hopefully I'm making sense.
Makes perfect sense. 12 volt systems often had 6 volt coils but had a wire from the starter solenoid to provide 12 volts to the coils when cranking. You were thinking of doing the same type of thing using a diode.
That was the plan but considering the coil most likely has an internal diode, the additional wire from the starter solenoid would probably not improve any additional volts.
