ballast resistor
Old Nov 9, 2008 | 05:57 PM
86fn150's Avatar
86fn150
ballast resistor
hi. i'm replacing my coil with a msd 8205 coil.has the same hookups etc.the general instructions say to put in a .8 ohm ballast resistor but on the msd site it says the resistor is for points ignition.my 86 f150 5.8 has the duraspark(blue module).a buddy told be the truck may have a loom resistor already inline???do i need the .8 ohm resistor???
any help appreciated.thanks in advance,
andy
Old Nov 9, 2008 | 06:49 PM
JimsRebel's Avatar
JimsRebel
My 1986 F-150 had a “resistor wire” between the key switch and the 4 pin plug on the left fender well, near the duraspark ignition module. The duraspark ignition needs to uses a ballast resistor or resistor wire for the round coil.
To confirm that your current coil is using a reduced voltage, compare the voltage of the battery positive with the coil positive with the truck running at idle. If your current system is using a resistor wire to power the coil, the coil voltage will be lower than the battery voltage and then you won’t need the ballast .8 ohm ballast resistor.
More info here.
https://www.ford-trucks.com/forums/7...-150-woes.html
Jim
Old Nov 9, 2008 | 07:04 PM
86fn150's Avatar
86fn150
awesome info.thanks a bunch
Old Nov 10, 2008 | 03:42 AM
Opossum's Avatar
Opossum
As long as the voltage at the posative side of the coil is about 9v with the engine running your OK.
Old Nov 11, 2008 | 09:50 PM
Piffery1's Avatar
Piffery1
The resistance wire in the wire loom is 1.1 Ohms which may be a little high for your coils voltage requirement. It should work OK but may not provide the maximum performance you'd get with the manufacturers recommended 0.8 Ohms.
tetraruby
24
Aug 4, 2013 02:26 PM
wavetrain75
Mar 7, 2013 12:44 AM
FordMan2
Jul 26, 2007 08:07 PM
PaulzF150
Feb 10, 2005 03:06 PM
Woody3221
Nov 10, 2004 10:35 AM
