Brake Controller Wiring, not tow equipped
Old 04-03-2014, 07:18 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
99% certain the Ex wasn't built with the tow package option, however it does have the appropriate hitch and 7-round connector. Went to pick up a Prodigy controller today and I'm having some issues with the wiring - as in I have NO idea where to look. I found a bundle of wire ends that seem to match the controller harness color scheme with the exception of the blue on the controller. I have the four wires under the dash that run from the center outwards and terminate along the floor heat duct. One black, one red, one white solid and one white with blue tracer. Are these the correct wires? May be towing a car up from Portland for a friend of mine, old Galaxy hardtop convertible on an 18' tandem flatty - I'd like to have the use of the trailer brakes considering the typical Seattle drivers and traffic...
Old 04-03-2014, 07:41 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
You should have a grey plug under the dash, look near the trans tunnel under the dash.
Old 04-03-2014, 07:56 PM
Archion's Avatar
Archion
Archion is offline
Those are the pass through wires from the engine compartment. I actually had to pull my center lower dash panel to get to my plug. It is straight down from the 4wd switch You did buy the adapter harness right?
Old 04-03-2014, 09:06 PM
Keving150's Avatar
Keving150
Keving150 is offline
On my 2001 I had to drop the trim panel below the steering wheel. Once I did that there was a metal bracket with about a 2 1/2 hole in it just below the 4X4 switch.....the plug was just through that hole in the bracket.
Old 04-03-2014, 11:23 PM
Krazee Matt
Cool thanks guys I'll dig around in there a little bit more.
Old 04-04-2014, 12:02 AM
Krazee Matt
This little guy? The grey connector?
Archon, I sure didn't snag an adapter harness. The sales guy was kind of clueless, same as me, and the tech was out for the day.
Old 04-04-2014, 01:18 AM
ExxWhy's Avatar
ExxWhy
ExxWhy is offline
Received 2,160 Likes on 567 Posts
That might be it. Once you have the standard Ford adapter harness, you'll know for sure. It plugs right in.
Old 04-04-2014, 05:13 AM
Magnus E's Avatar
Magnus E
Magnus E is offline
Old 04-04-2014, 05:30 AM
Archion's Avatar
Archion
Archion is offline
Yeah, that's it. Grab the harness and you are GTG.
Old 04-04-2014, 07:12 PM
Mach1394's Avatar
Mach1394
Mach1394 is offline
With these guys^^ Thats the plug you are looking for
Old 04-04-2014, 11:33 PM
Krazee Matt
Thanks to all, got the controller hooked up, functioning, and adjusted properly. Appreciate it fellas
Old 04-05-2014, 12:07 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I know it's a little late, but this is the picture I've posted for 8 years to help people out whenever these threads pop up.
Stewart
kell104
05-29-2016 01:56 AM
Bergfurher
01-17-2010 09:37 PM
stroker870
03-23-2009 10:46 AM
lionsteve
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-06-2007 03:17 PM
1stjd
13
07-15-2003 07:34 PM
Quick Reply: Brake Controller Wiring, not tow equipped
