Long story short trying to loosen up the adjustment on my steering gearbox but adjustment nut won't turn. I loosen up locknut and try turning the adjustment allen nut but I'd won't turn. Can you loosen the play in steering or can you only tighten?*
You did...You need a new box. Sector shaft adjustment should be done in small increments if at all....Don't feel bad, I did the same thing. Replace it before you kill yourself.
