Fuel pump humming?
Old Apr 3, 2014 | 09:44 AM
mrrish79's Avatar
mrrish79
Fuel pump humming?
After doing some searching I couldn't find any information on the forum. When I'm running the rear tank there is this humming sound, I have pin-pointed it to the rear tank because it goes away when I switch tanks. It does this when its full or near empty. Nothing has come of it truck still runs and burns fuel just wanted to see if anyone has had this happen. Is this an early indication of my rear fuel pump going on me?
Thanks!
Old Apr 3, 2014 | 10:19 AM
White Max's Avatar
White Max
Electric fuel pumps aren't exactly silent, but if it has become noticeably noisier, it can certainly be a sign of the pump being "on it's way out".
Old Apr 3, 2014 | 10:30 AM
Island'r's Avatar
Island'r
Every Ford I've owned has had somewhat of a "noisy" fuel pump. A fairly high pitched hum/squeal is normal.
Not nearly as noisy as the famous ford Power Steering pumps though
Old Apr 3, 2014 | 04:13 PM
eakermeld's Avatar
eakermeld
On both of my Fords, the rear pumps are noticeably noisier than the front ones. Doesn't seem to affect anything, though.
Old Apr 3, 2014 | 08:29 PM
mrrish79's Avatar
mrrish79
Ok thanks for the info. It just started was my only concern. It's not too loud just was a new sound I hadn't heard before. My 90 F150 never made this sound in the years I owned it.
Old Apr 4, 2014 | 11:43 AM
Encho's Avatar
Encho
The Southernmost Mod
Actually, if you never heard the pump before and you're now hearing it, it probably is on it's way out. If I were you, I would carry a replacement around or save me the aggravation of a road-side repair (even though when it dies it will probably do at a parking spot) and replace it when I have a moment. Of course, it all depends on the age of your current pump. Anyway, sometimes when the pump is about to completely fail it gives a few warnings, like failed starts and engine deaths, and you can just hit under the truck at the fuel tank to get it un-stuck and at least drive home, a couple of firm whacks at the fuel tank should suffice.
Old Apr 4, 2014 | 02:33 PM
mrrish79's Avatar
mrrish79
I do have two tanks that both currently work and never drain one I always leave about $10 in the empty tank and when I fill up I alternate to keep the gas fresh as I don't drive this truck but one or two days a week I have two other vehicles.
Thank you for the information!
jerg_064
Oct 29, 2008 07:46 PM
tony b
Nov 4, 2006 10:10 AM
moose94
33
Jun 30, 2005 12:03 AM
rhetor
Jan 14, 2003 11:27 PM
tugboat
Mar 12, 2001 09:19 PM
