Early 99 - Bad Multi Function Switch?
Old Apr 2, 2014 | 07:47 PM
Old and Busted's Avatar
Old and Busted
Hi all,
Searched at length through the FTE forums and google without finding a similar thread. A number of problems started today that seem to point to the multi function switch. It all started with a fast blinker that when cycled would sometimes go back to a normal pace. All bulbs, fuses and easily visible grounds appear fine. Knock on wood, this is the first real electric problem I've had with this truck. Here's some of what is going on:
-With headlamp switch off and the key in the #2 position the running lights/brake lights are lit
-Brake/running lights illuminate very dimly with the key off when the brake pedal is depressed
-Blinker blinkers fast with no other lights on then goes dim and freezes with the running lights turned on or the brake is depressed.
-Hazards blink fine with no other lights on then slow way down with the running lights on or the brake depressed.
-Wipers, washer and high beams appear to function fine.
Does this seem like the multi function switch? Some threads say the switch is can be cleaned...is that realistic? Thanks in advance for the help.
Old Apr 2, 2014 | 08:13 PM
rcgtsport's Avatar
rcgtsport
my guess would be a wire is shorting out by brake switch or steering column. look for insulation on wire rubbed off. just my 2 cents, good luck!
DJ Kontakt
19
Feb 14, 2018 11:55 PM
eddie a
Jul 30, 2015 08:15 AM
Lukes66
Feb 9, 2011 05:38 AM
Dustin_86
Dec 29, 2004 09:42 PM
phmco
1997 - 2003 F150
Nov 15, 2003 07:35 PM
