Wheres my frame cab mounts?
Old Apr 1, 2014 | 06:55 PM
MdubbU's Avatar
MdubbU
I got my cab off the truck today and my mounts are gone I hammered the rubber mounts right through them. Cant find new ones to buy any where and cant seem to find a washer 3 5/8" to weld in there. any one know of a write up to fix these, buy new ones or buy washers that big?
Pics of the damage
Oh and the front left of the frame has damage from an wreck, need to find a frame going to scrap and cut that out. Or try and fix it with heat and welding.
Old Apr 1, 2014 | 07:26 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Get rid of the rust, weld in new 3/16 plate steel. Weld it in on the underside to have the flat edge to get a good attachment point.
No welder at home, take them off and take to a local welding shop, not a big job at all.
Old Apr 1, 2014 | 07:41 PM
MdubbU's Avatar
MdubbU
do you happen to know what size hole is suppose to be in the middle for the th rubber mounts?
Old Apr 1, 2014 | 07:42 PM
77&79F250's Avatar
77&79F250
Ah no... but you do have the old mount hdwr don't you?
Old Apr 1, 2014 | 11:29 PM
gpence's Avatar
gpence
I'm scraping out a F150. I'm in Nebraska tho.
Old Apr 1, 2014 | 11:36 PM
turbohunter's Avatar
turbohunter
Here's a page from JBG with lots o' repair stuff.
1967-79 Ford Full Size Truck/Bronco Body Mounts & Hardware
Old Apr 2, 2014 | 05:40 PM
MdubbU's Avatar
MdubbU
thanks. that really helped. parts are on order now.
Old Apr 2, 2014 | 05:57 PM
turbohunter
Good luck with it.
Old Apr 2, 2014 | 06:01 PM
MdubbU's Avatar
MdubbU
yeah should be a real treat lol. im going out and buying a welder tomorrow to fix these thing along with a few other spots the need repaired on the chassis. now I have to figure out what to use for rubber mounts with out spending a ton of money. the front two cab mounts I was un able to separate due to rust.
Old Apr 2, 2014 | 06:06 PM
turbohunter
Well you've got a lot of work ahead of you, but others have started with the same.
At least you'll know every nut and bolt on it.
For inspiration when you get pissed you might check out this thread.
https://www.ford-trucks.com/forums/8...with-pics.html
Again, good luck.
Old Apr 2, 2014 | 06:09 PM
MdubbU's Avatar
MdubbU
hey turbo thanks! I know when theres days I cant do anything I always poke around on here for info an that keeps me going.
Old Apr 4, 2014 | 03:46 PM
MdubbU's Avatar
MdubbU
welp...parts showed up from bronco grave yard. Wish I would of know how close they were. its only a 15 min drive down the e-way, think I will be making a trip to the BGY here soon to look around.
hitchpin1
Large Truck
Jul 1, 2011 09:44 PM
rbig1
Mar 18, 2010 11:42 PM
gbroehl1
Paint & Bodywork
Nov 3, 2006 04:19 PM
cujo8
Sep 29, 2006 07:40 PM
54ford
Dec 2, 2005 05:14 PM
