cab frame mounts
Old Mar 15, 2010 | 08:08 PM
rbig1's Avatar
rbig1
cab frame mounts
what size hole is in frame brackets. and does any one know measurements. i have a 76 and a 78 f250 high boys both have two that are bad and i need to repair them. switching cabs arround on them.
Old Mar 15, 2010 | 08:23 PM
Hyperactive460's Avatar
Hyperactive460
try this guy for new/used mounts. i bought mine from him about 3 years ago. ( check gallery ). Payments & Refunds : Zen Cart!, The Art of E-commerce. if i remember i can get some measurements off my frame tomorrow after work.
Old Mar 16, 2010 | 07:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Bronco Graveyard sells "frame savers". These look like large flat washers that you weld over the original mount hole.
These will work if the hole is rusted out but not if the whole mount is trashed.
Old Mar 16, 2010 | 09:19 PM
rbig1's Avatar
rbig1
on those washers would you weld underneath so as not throw cab out of whack. and fill it weld.
Old Mar 18, 2010 | 11:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You could probably do it that way. I personaly haven't had to use them but all the ones I have seen have been welded on top. They are not that thick (~1/16"-1/8")
soupcancowboy
Nov 16, 2013 11:48 AM
tnguynaford
Jul 8, 2013 01:25 PM
MattyJessome
Aug 17, 2010 11:47 PM
Mark223
Jan 18, 2010 10:46 AM
19FORD93
Sep 2, 2007 06:33 PM
