tightening 2005 f150 2wd front spindle nut to 295 ft. lb. spec and rotor locks up.not sure what to do.tighten till locks up and back off till free?thanks for any replies in advance
There is something wrong, why did you take off the nut in the first place ?
Did you replace the rotor ?
The nut basically keeps the rotor from falling off , their is no preload on the sealed bearings like on the old bearings.
Even if you tightened it to 395 lbs, it shouldn't effect the rotor turning.
By the way , did you put on a new nut like Ford instructs ?
