Modular V10 (6.8l)
2008 F250 V10 Knocking
Old Mar 31, 2014 | 11:37 AM
ashmoremw's Avatar
ashmoremw
I have a truck that has been a bit of a restore due to flood damage but I only want to touch on that. When I got this truck there was water everywhere you could imagine. Crank Case, Cylinders, Transmission, ETC... The truck is running now thanks to finding a 09 F250 that had been rolled over to salvage parts from. My big issue right now is the knocking noise coming from deep in the engine. At first I was told exhaust manifold bolts are common for these engines to break thus creating a knocking lifter noise. After I got deeper into the issue and replaced a few exhaust manifold bolts because they were in fact broke.... Using a stethoscope the noise is coming from the bell housing of transmission. Is it possible it is a bad torque converter or is it a connecting rod knock making its way through the crank shaft and being amplified in the bell housing. I can not pick up the noise on the block anywhere with the stethoscope but the bell housing is very distinct. Any thoughts????
Old Mar 31, 2014 | 05:06 PM
pappy19's Avatar
pappy19
I'd buy about 5 bottles of Auto RX and run it through engine, tranny and transfer case. If you still have a knock, then it's permanent damage.
Auto-Rx Plus Non-Toxic Sludge Remover and Cleaner for Engines and Transmissions
Old Apr 2, 2014 | 10:33 AM
OVER 50's Avatar
OVER 50
Check your flywheel bolts, make sure they are tight. check your flywheel for cracks. this was a common problem a few years back. JMHO
f100blighty
21
Mar 9, 2017 06:14 PM
xtremexj
Oct 22, 2013 09:43 PM
lasmacgod
Modular V10 (6.8l)
16
Oct 19, 2010 11:48 PM
jnj4fords
Nov 17, 2005 06:39 PM
puppy
Nov 20, 2001 12:29 PM
