Scarey Engine Noise
Old Oct 30, 2001 | 10:39 AM
puppy's Avatar
puppy
Scarey Engine Noise
I have a '97 Expedition, 5.4, 4wd automatic w/ 70k miles. It has developed a loud internal rattle at idle and occasionaly at driving speeds that sounds like a loose bolt whirling around the bell housing. It occurs randomly and does not have a constant frequency like rod, main or piston noise. Since it sounded like it was in the back of the engine, I suspected the starter gear was not fully retracting and occasionally would strke the flywheel ring gear. After removal I see no evidence of that happening. Removing the inspection plug and plate from the bell housing, I see no metal shavings or loose pieces although my view is limited. The noise changes in frequency with engine speed but not in a constant manner. Another nightmare might be the oil pan wingage tray is loose and moving around with oil level. Seems a little remote. Short of removing the transmission to inspect the flywheel and torque converter, does anyone have any suggestions. I tried to pinpoint the location but it is so loud it could be emminating from anywhere other than the top side.
Old Oct 30, 2001 | 05:34 PM
adelyser's Avatar
adelyser
Scarey Engine Noise
The only time I have heard a noise like that is when the catalytic converter is shot. I have had that happen on two different vehicles, and it sounds like hell. Other than that, I have no idea. Good luck!
Aaron D
Old Oct 31, 2001 | 06:32 AM
puppy's Avatar
puppy
Scarey Engine Noise
Thanks Aaron,
Forgot to mention that I too thought the driver's side catalytic converter was the source and went through the grief of breaking and repairing manifold bolts to get it off only to find nothing loose inside. Changed the starter last night. Still is the most likely candidate. I'll keep your experience in mind. Thanks again for the help.
Old Nov 19, 2001 | 12:39 PM
puppy's Avatar
puppy
Scarey Engine Noise
Update: A new starter eliminated the noise. Guess the gear was failing to retract.
Old Nov 20, 2001 | 12:29 PM
shomby's Avatar
shomby
Scarey Engine Noise
NompNasty
May 4, 2017 11:13 PM
oachs83
1997 - 2003 F150
Sep 8, 2016 06:19 AM
andym
22
Jun 27, 2014 02:11 PM
'06Roush_150
2004 - 2008 F150
Mar 25, 2014 12:56 AM
E150
3.8 & 4.2L V6
Sep 14, 2009 01:10 PM
